what resistor value for 2 indicator LEDS
mojoh
Post by mojoh »
i use a 2k2 resistor for a single 3mm indicator LED...if i wanted to have 2 indicator leds wired in series...what resistor value do i use???
cortezthekiller
my favorite amplifier: A large highway overpass
Has thanked: 20 times
Been thanked: 52 times
Post by cortezthekiller »
I think anywhere from 1-2k should be reasonable for limiting the current to the leds
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
You need to know the nominal curent for your LEDs and the Forward voltage.
Example: I=20mA. Uf=2.2V.
You need the resistor to limit the current to 20mA (LEDs in series) and to drop the voltage by 9V-(2.2+2.2)=4.6V
This way, your LEDs voltages added to the resistor voltage would bring you up to 9V, and the nominal current is flowing in both LEDs...
Ohm's law says: R=U/I... 4.6/0.02=230 ohms.220 ohms would be brighter, 270 would be more reasonable?
Now you compute your own values... :wink:
edit: just remembered you mentionned you actual resistor value... Yes, i would go fo something like 1k3
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
