Need Peavy pedal schematics.
- nickthemen
- tube-exorcist
You didn´t use the search function, did you ?
https://www.freestompboxes.org/viewtopic ... 52&start=5
- kusi
here are two schematics for other peavey 80`-pedals
regards, kusi
regards, kusi
PEAVEY_DirtyDog.pdf- (627.17 KiB) Downloaded 316 times
PEAVEY_AOD2.pdf- (211.36 KiB) Downloaded 333 times
- Dirk_Hendrik
