Skreddy Echo [gut shots]
Damon Jonesta
Been thanked: 15 times
Post by Damon Jonesta »
guts
Lawnchair
Been thanked: 16 times
Post by Lawnchair »
Reasonable parts count. Hack it! :horsey:
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
The ground wire looks like a dirty ivy plant... Beurk!
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
WhiteKeyHole
Has thanked: 24 times
Been thanked: 219 times
Post by WhiteKeyHole »
PM@me the schematic, Skreddy.
PM@me.
jimbojetset
Post by jimbojetset »
Is there a schematic for this pedal anywhere?
cheers.....
Damon Jonesta
jimbojetset wrote:Is there a schematic for this pedal anywhere?
cheers.....
sure
bestegw
Post by bestegw »
OK, let's see what we've got:
* PT2399 all-in-one delay chip
* OPA2604 op-amp (love those!!)
* LFO-LDR combo for modulation of the delay time
* one of the Q's is probably 78L05 voltage regulator (probably Q1, based on the position next to PT2399)
* 3 types of film caps (Greenies, Panasonic, MKT)
* carbon comp resistors (in the audio path???)
My first thought was that it's a modded Rebote delay with a trem-like circuit connected to the delay time.
Build quality looks very good with the pots attached to the print. I also like the method where you can reach the trims from the outside :applause:
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
what's the LED/LDR there for?
[edit] oh, the LFO :slap: [/edit]
Look up the scheme for the Yerasov delay to get an idea for how the delay time is controlled. It uses a transistor for the variable resistor element. Marc had mentioned it to me as a cool way to do it, so I'm guessing he's doing something similar here. The LDR is likely controlling a voltage that's affecting that transistor.
bestegw
Post by bestegw »
So, basically you set the voltage of the base of the transistor, thereby determining the output at the collector-side. Pardon my simplicity, but why wouldn't you just connect the time-pot to lug 6 of the PT2399, like on the rebote or similar pedals? Is this more stable?
BTW, connecting two PT2399's together on the Yerasov looks like a cool idea. The thing sounds very nice and ambient:
Diamond
my favorite amplifier: Blackface Fender Bassman
Completed builds: Ampeg Scrambler, Fuzz Face x4, Fuzzrite, Tonebender MKII, Green Russian Big Muff, Green Ringer, Colorsound Overdriver, Nurse Quacky, Ross Phaser, Rebote 2.5, Blue Box.
Post by Diamond »
That looks pretty tight! Great sounding pedal though.
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Would be great to combine this circuit with the NE571 compander, as used in the PT-80.
bestegw
Post by bestegw »
I've been checking some of the delay schematics out there (Rebote, Echo Base, Yerasov and Magnus Modulus) and considering the possibilities of this delay, it's most similar to the Echo Base. This pedal also uses the delay-time-via-a-transistor method that Soulsonic mentioned.
Could it be that Skreddy has been optimizing the Echo Base to the Skreddy Echo (perhaps even with a name reference???) with carbon comp resistors and film caps in the audio path?
The idea with the compander-expander sounds pretty cool too and would IMHO contribute to an even more analog-sounding delay.
Skreddy, care to share some with us?
All the best!!
Bestegw
sevinisthenumber
Been thanked: 29 times
Post by sevinisthenumber »
Can tap tempo be added to this??? I know of other pt2399 based delays that are... Thanks
C.S. Lewis
soggybag
Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
Has thanked: 28 times
Been thanked: 27 times
Post by soggybag »
I built a PT-80 and it sounded pretty good. I'm not sure that is sounded so much better than the Rebote that it was worth building with the extra NE570 and related components.
Skreddy sure loves those carbon comp resistors. For some reason I could not bring myself to use these in a delay.
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
Looks like a single transistor phase shift oscillator.
Ref: http://www.electronics-tutorials.ws/osc ... lator.html
Output drives and LED aimed at an LDR in parallel with the "time" resistor.
"Modulation" controls are pretty self explanatory: Speed controls frequency of oscillator, Intensity controls current of LED.
It looks like inductors(?) used in the feedback loop of the PT2399? Neat idea if so.
Effects loop probably interrupts feedback of the echo circuit.
Nice opamp to drive the echo circuit, and mix the echo and dry paths.
Tap tempo on PT2399 is not exactly stable, or easy.
There's a drop in module a guy designed:
http://www.thoughtprocessinc.com/ptap
You will find it in a few "diy"/"boutique" designs. It comes with its own host of instabilities, which if are not immediately apparent, will be discovered shortly after its installation. I'm not knocking the designer of this device. Its in the PT2399, which is a fantastic chip!
There are just easier ways to go about designing a tap tempo delay.
I don't think Marc copied anyone's design. Its a PT2399 based delay. There's only so many ways to use that chip. The magic lies is what you do with it.
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
More gut shots, courtesy of The GAS Station at TGP.
First two are an older model, last two are from the 2010 version.
culturejam
A few more gut shots from TGP.
I'm really surprised this thing is as expensive as it is and doesn't have a compander.
monkeyxx
Has thanked: 52 times
Been thanked: 49 times
Post by monkeyxx »
any new info or circuit trace side pictures of this around? I'm pretty intrigued by this thing. the price isn't that bad, actually
Damon Jonesta
Work in progress
:applause:
