EH - Bass Micro Synth
pollomartian
Post by pollomartian »
Can you post the PCB project for edit? I would like to do the pots PCB designed for use potentiometers instead of faders.
Thank you very much, from Spain
J.I.
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
here
EH bassmicrosynth pots konacno.zip
(268.88 KiB) Downloaded 318 times
Gila_Crisis
Post by Gila_Crisis »
This is a "factory schematic" I found years ago.
I think it is super accurate, as I used to have a Micro Synthesizer (a 90s reissue) at some point, which I modified to Bass spec (the values are reported on the first page), and twisted a bit the octave circuit to have a better sounding octa-up fuzz.
All thank to this schematic!
Micro_Synthesizer.pdf
(57.77 KiB) Downloaded 58 times
