now the next project is a BOSS CE-1 but maybe doesn't work??? i found this forum and looks that they have a looooong time working and trying
http://www.guitarrista.com/phpbbforum/v ... 29&t=24270
someone who tried that project???
lufox15 wrote:now the next project is a BOSS CE-1 but maybe doesn't work???
lufox15 wrote:well, some blury pics of my microsynth, i didn't find linear pots so i use regular pots. but works totally fine!. Thanks to borislav for begin the post and to everyone who helped!!!
what transistors you used?lufox15 wrote:well i use the compact pcb that robertmaz posted, all CI in there are CA3094 that i bought on smallbear. the tracking works fine except the last part, in the pic you will see a little blue wire. that part of the track must be connected to ground or -Vcc i dont remember, but if you review the pdf of schematics the last CA3094 isn't grounded.
Here a sample that i made of this amazing pedal.
I'm waiting for some pictures more close for make the new version, the Attack delay stage and suboctave are different on the new version but i can't see it on the pics. or maybe someone could try make a adapter for LM13700 or LM13600 i don't understand to much about analog electronics. i try to connect a lm13700 with two transistors but doesn't work, maybe i try in a bad way.
I have heard to much about the Ce-1 and the sound of chorus is more warm, i have made a CE-2 but i'm not convinced.![]()
sorry about my english.
well the ce-2 sound not so organic for me, and the ce-5 schematic looks similar, have filter stage next from the 3007 and 3101.roberttomasz wrote:I have lodged CE-2 and they walk without objection CE-5.
are the same numbers of the schematic of the PDF (3pages)gtr-fxr wrote:does anyone know of a parts list to use for the single pcb version?
both layout use the same part list on the first page of this topic, published by jazzmastergtr-fxr wrote:that's what i was wondering about, i'm guessing you mean the one's from roberttomasz right?
you are right....if you have triggering, then rectifier works OK.....than you search from there ...it must be something near octave pot.......lufox15 wrote:Hi Luqqas i read your message about the start frecuency, start frecuency works only when you play the guitar and the note or chords active the attack stage, if doesn't work maybe you need adjust the trimpot pre-gain on the circuit and set the trigger pot to max, should works.
On your problem on the octave up stage, you must see the traces or the components between the point 3 to point 4 on the schematic (around IC A3A and A3B) there a rectifier stage that produce the octave up or see if the squelch trimpot is working good, maybe could it be the octave pot.
