R. Gwinn, Gristleizer  [documentation]
reneshelle
Has thanked: 35 times
Been thanked: 47 times
Post by reneshelle »
The Bias knob should for sure be linear.
The level and Depth should probably be linear as well and the Speed be log, but they seem fine to me the way I’ve written them.
The letters A and B must have confused me…
TheLoneRoger
Post by TheLoneRoger »
R.G. wrote:There's a schemo and PCB layout at GEO.
Who/where/what is GEO?
I'm looking for the docs that came with the original Phonosonics PCB for this project having lost mine - not sure if this is the one, but I'd love to find out...
http://www.geofex.com/Article_Folders/gristlecheck.PDF
TheLoneRoger
mictester wrote: 15 Mar 2013, 06:18 The final mod I sometimes add is to give the first stage the option of a clipper circuit in the feedback path - the additional harmonics really make the VCF shine!
Many thanks for this. I had literally just finished re-building and boxing my original PE/Phonosonics Gristleizer, which I first built in the early '80's, when I came across this post!
I'll be implementing your mods - swapping the IC's etc. - but could you elaborate on the last part? How/where would I add this clipper circuit to the original PE layout?
TIA
Roger
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
The simple clipper I've used is to put a pair of back-to-back diodes in parallel with the 100k feedback resistor in the first (input buffer) op-amp stage. Later, I changed the 100k resistor for 56k in series with a 470k pot wired as a variable resistor, so you can vary the amount of fuzzy clipping.
TheLoneRoger
Excellent, thanks - I'll be giving that a go for sure!
