Should be boxed up by tomorrow, still baking the clearcoat. Great sounding pedal. Insane amounts of both output (unity is about '3') and gain (Abuse), where that knob is basically unusable howling screeching feedback above about 3/4 - I did however use a 10K pot for lack of a 1K on hand, and expect that may be the very minor problem. Also, I find the VR has very little effect, tho some. Still have to add knobs.
keto wrote:Should be boxed up by tomorrow, still baking the clearcoat. Great sounding pedal. Insane amounts of both output (unity is about '3') and gain (Abuse), where that knob is basically unusable howling screeching feedback above about 3/4 - I did however use a 10K pot for lack of a 1K on hand, and expect that may be the very minor problem. Also, I find the VR has very little effect, tho some. Still have to add knobs.
Love the case!!! The "abuse" pot was originally a 5k, but found to be usable only over about 15% of its track, so it became a preset with a 1k pot in series to cover the usable bit!
I warned you that it was LOUD[/color]
I've just drawn up a more compact veroboard layout for this awesome-sounding fuzz (many thanks, mictester!). Please note it is unverified until my parts order arrives and I can actually build and check it: You should compare it to the schematic to double-check my work if you plan to build it (I've gone over it many times and it looks fine, but you never know).
modman wrote: ↑Let's hope it's not a hit, because soldering up the same pedal everyday, is a sad life. It's that same ole devilish double bind again...
Got it up and running late last night just to check it, and it sounds great. Haven't messed with the trimmer (set to about half way and it sounded pretty cool), and I've only tried a 220n and 10uF input cap, but I'll spend some quality time with it tomorrow.
Many thanks to mictester for the fantastic schematic.
Thanks for the Schem mictester, thanks for the layout Nocentelli. I think I'll give this try.
I have a bag of transistors labeled BC109 in my parts bin. I'll assume that these should work. They are small metal cans with gold legs. I have five. I'm not sure if these are the "c" type, would this make big difference?
What would be a good substitute from the US transistor line, like 2n5089?
Does the gain matter? What type of gain does this circuit prefer for best performance, or does it matter?
soggybag wrote:I have a bag of transistors labeled BC109 in my parts bin. I'll assume that these should work. They are small metal cans with gold legs. I have five. I'm not sure if these are the "c" type, would this make big difference?
I believe the "c" suffix just indicates higher gain - plain old BC109 will work fine. I also believe that BC108s will also work, as the datasheet (http://www.datasheetcatalog.org/datashe ... _109_4.pdf) seems to indicate the only difference between 108/109 is a higher minimum gain and lower noise: I'm sure I read a post from analogguru a while back saying that they just make a batch of transistors and the lower gain ones are designated BC108, and the higher ones BC109 (and presumably within that group, the highest are designated a sub-set BC109c). I may be entirely mistaken, however.
soggybag wrote:What would be a good substitute from the US transistor line, like 2n5089?
I think 2N2222 are the US equivalent.
No - the 2N2222 is quite a low gain device. You really want to look at the 2N5088. I've built these using BC184L, BC550, BC549C, 2N3707, BC109C, BC109, and one or two others. You just need a fairly high Hfe (180 minimum) and the thing will sing and howl!
Oops, I was going off modman's advice in this thread.
It certainly does howl with a set of BC109c's: Very long sustain with gain up high, and just a tiny bit of gated decay at the very end of the note (if it doesn't go into infinite harmonic feedback).
Thanks for the replies. I have plenty of other transistors. So I can audition them all. I was just trying to figure out if this circuit required transistors with any special qualities. Sounds like something medium high to high gain would work.
Which reminds me about the pin out. Looks like the BC109 is CBE and the 2n5088 is EBC. I'll have to take a close look at the stripboard layout.
soggybag wrote:Which reminds me about the pin out. Looks like the BC109 is CBE and the 2n5088 is EBC. I'll have to take a close look at the stripboard layout.
The BC109s I have are all metal cans with the tag to mark the emitter - .
Since DIYLC only has the standard transistor image, using my layout you need to orient all the transistors so emitters are at the bottom, base is central and collector at the top: e.g for Q1, emitter = e5, base = d5, collector = c5.
A month later and I've finally gotten around to finishing this one.
Sounds good, the fuzz so thick you could cut it with a knife. I used Nicotelli's layout. Worked on the first try. I found a few BC109CNs in my parts bin. I tried another weirdo low gain, ~50hfe, transistor in a few spots. Sounded good in Q2, Q3. Didn't quite have the gain in Q1. I might have to try a few more transistors. Though I'm suspecting the sound will not be that different. This is very fuzzy.
soggybag wrote:A month later and I've finally gotten around to finishing this one.
It's meant to be "very fuzzy", and not to have the thermal problems that I've almost always experienced with germanium-based circuits.
It's actually one of the most controllable fuzz circuits I've ever used. I now have built a version with a wider "fuzz" control sweep (from gated and fizzy through to thick and creamy with stupid amounts of sustain!). I also added my favourite tone control (the "James" type) with a buffer after it. It's a wonderful pedal for many styles of playing, and sometimes I can't keep up with the demand for them!
The closest transistors I have to BC109c is some black plastic case BC549c Si NPN transistors,these are described as low noise hi gain transistors,I measured the gains of some of them which turned out to be as high as 700 or so,these should work okay,shouldn't they?
