Can a layperson create a 3D CAD file if the shape is fairly simple? Basically a triangular prismic shape with a threaded knob protruding from its base, pretty simple; is this something I should be paying a service to create or, given CAD software, could I (with no experience with graphic design) get the job done? Thanks!
Completed builds: Completed builds : Proco Rat MXR MicroAmp in a volume pedal TubeDriver (w/ NoS russian tube and big muff tone contol) + Phase 45 (w/ univibe cap ratio) Dallas Rangemaster (w/ noisy OC75, negative ground) SubCaster tube booster (w/ NoS russian tube, PtP) Hot Harmonics Music From Outer Space SubCommander in progress Crackle Not OK Simple bass blender in a 1590A Bazz Fuss with a photo-darlington
eleesha wrote:Can a layperson create a 3D CAD file if the shape is fairly simple? Basically a triangular prismic shape with a threaded knob protruding from its base, pretty simple; is this something I should be paying a service to create or, given CAD software, could I (with no experience with graphic design) get the job done? Thanks!
For something that simple, you should be able to do it yourself with tools like Google Sketchup.
And there are plenty of Free (libre) software like Blender, but they have a bit steeper learning curve.
WHat is the difference between manual engineer drawing and autocad ? what is the convenience, speed, safeguards required, financial outlay, quality of output and storage issues. for autocad and manual engineer drawing.
