diy capacitors
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 75 times
Post by Jarno »
This guy in Israel built his own 60' Jazz Bass, right down to the PIO cap, check it out: TDPRI.com thread
Anyways, it looked so easy that I didn't think it would work, so I tried myself :-)
I glued aluminiumfoil strips onto paper strips, rolled them, and soaked them in mineral oil (the stuff they use to lubricate sewing machines).
First try:
Not very successful, because the alu foil shorts, I did get enough capacitance on the meter to make me want to try again.
Try and try again:
620nF! Not bad, it does leak a bit (DC resistance 1,5M) so I wouldn't use it in a tube amp. Also, sealing is important, I left it hooked up to the meter unsealed and checked every couple of days, as the oil leaked away, so did the capacitance.
wow Jarno, that is quite a thread! thanks for the link and the pics of your experience giving it a try. do you think you'll ever try actually potting one fully and finishing it off? and do you know how to adjust the amount of capacitance?
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
You mean the build thread of that Jazz Bass? Yes, that is one dedicated guy right there!
I am not sure I will be potting diy caps anytime soon, although I am curious to see if they sound different/ better. You can adjust the capacitance by either the distance between the conductors, the surface area and the dieelectricum (in my case paper). I have found formulas to calculate the capacitance of flat plate capacitors, but my second test ended up much higher, so there is probably a different set of formulas involved.
