Okay
I just built analogguru's +15vdc and -15vdc from a +9v power supply (9v switchmode power supplies are cheap and plentiful these days - at least where I live!!)
I used a +9vdc 1300mA switchmode adaptor - unloaded it measures 10vdc.
I used standard 10uf 25v aluminium electrolytics and 1N4148 diodes, polyester 100v film caps and non mojo metal film resistors
I measured +21vdc and -21vdc at the output terminals - no effect connected -The current draw measures 12mA.
I made a simple circuit with a TL082 opamp - a non inverting buffer followed by an inverting gain stage.
I connected the circuit to the power supply using 100 ohm series resistors - the measured voltages at the op amp supply rail pins was +18vdc and -14vdc approximately. I checked the supply current draw - 28mA, however the voltage drop of 0.4vdc across each of the 100 ohm resistors means the dual opamp TL082 is only drawing 8mA total current.
Not sure why the -ve rail is 4vdc lower than the positive rail though.
The next step is to see how or if it can feasibly power up 3 TL084 quad opamps.
I will keep you all posted, but initially this looks good - thanks to analogguru once again
