Blend circuit with boosts + feedback loop
squrl
Post by squrl »
i figured i would try my hand at a 'blender' type pedal with some useful additions, which include:
boosts in each split signal path (courtesy of soulsonic)
a simple feedback loop
phase inversion of the send/return path
running on a dual +9/-9v supply for increased headroom
i used fixed resistors for the boosts with a voltage divider at the end of those circuit portions for attenuation/boost - not sure if that's the best idea...
also, i wasn't 100% certain about using a voltage reference while also using a split supply - intuition tells me that the reference is half the supply so to send it to ground. not sure if i needed to 'float' the ground or something like that, though.
any comments are greatly appreciated as i'm sure there are some mistakes here...
Picture 3.png (11.04 KiB) Viewed 948 times
fosnal1950
Post by fosnal1950 »
Why use U741 opamps , the Tl opamps are much higher quality.
I would make the 220K resistor a trimpot for more flexibilty to set your gain.
squrl
Post by squrl »
fosnal1950 wrote:Why use U741 opamps , the Tl opamps are much higher quality.
ah forgot to add... the opamp values are only placeholders in eagle. i'll most likely be using a single LF412 in place of the two UA741 and a different quad than the TL084.
squrl
Post by squrl »
any ideas/suggestions before i hit the breadboard this week? :wink:
