Tronographic - Rusty Box
andrej
my favorite amplifier: Vox AC30
Completed builds: Zvex Woolly Mammoth
Boss DS-2 mod
Vox AC4
Crowther Hotcake (and own variations)
TS-808
Big Muff Russian
Big Muff IC
Superfuzz
Superfuzz
Big Muff
Mixer/Blend
various other stuff
Been thanked: 51 times
Post by andrej »
check it out (clips included):
http://www.tronographic.com/
http://www.talkbass.com/forum/showthread.php?p=6825564
it seems to be a copy of Traynor TS50B's preamp section. it runs on 50V. 190 bucks. sounds really nice: metallic, brutal. Bob Weston's favorite. He used it on Shellac's last tour through power amps.
this should be traced! if my bass player buys it, i'll post pics right away. unfortunately, they have no units for sale atm. maybe we could ask someone who owns it over at talkbass?
Emanuele
Post by Emanuele »
andrej wrote:check it out (clips included):
I would be nice to trace it..someone could build an all in one amplifier with that preamp and some bigger wattage power section..
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
andrej wrote:this should be traced! if my bass player buys it, i'll post pics right away. unfortunately, they have no units for sale atm. maybe we could ask someone who owns it over at talkbass?
Yes, please ask anyone you are friendly with at TalkBass to post or email you some gut shots. Then we can take a look at see what makes it tick.
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
Skyline FX 2013
andrej
Boss DS-2 mod
Vox AC4
TS-808
Big Muff Russian
Big Muff IC
Superfuzz
Superfuzz
Big Muff
Mixer/Blend
various other stuff
Post by andrej »
that was easy. an output buffer and a transformer and its done.
anyone wanna make a pcb? i'm currently on vacation, and don't have any of my programs here at my aunt's.
chicago_mike
What I find interesting is 2 things. The voltage requirements and the price.
I guess the price isnt too bad :| , but a 40volt wall wart, I thought at first it was tube.
Skyline FX 2013
invalidcd
Been thanked: 14 times
Post by invalidcd »
chicago_mike wrote:What I find interesting is 2 things. The voltage requirements and the price.
Thats what i was thinking :hmmm:
Hey, the preamp section only need +/-15v bipolar. You could do that with a 16vAC wall wart, no problem. I designed a ring mod recently that runs on that - worked perfectly on the breadboard from a 16vAC input, half-wave rectifiers, and got a simple regulated +/-15v with some resistors and zeners.
And if you wanted to run it on standard 9v, you could build up a boost/invert thing with one of those fancy chips they make just for that. Or, if the current requirements of the circuit are low enough, you could even get away with doing it with a 555 and a simple voltage multiplier thing.
jbrew73
Post by jbrew73 »
on the traynor schematic, what does the last section with the 6 mps8598 right before the master volume do? looks like some kinda fixed eq.
clintrubber
Has thanked: 16 times
Been thanked: 5 times
Post by clintrubber »
jbrew73 wrote:on the traynor schematic, what does the last section with the 6 mps8598 right before the master volume do? looks like some kinda fixed eq.
That's the actual section that sets it apart from other circuits. For a three-band compressor (which it is, called the "Tri-Comp Network") it has a pretty low number of components ! 8)
clintrubber
soulsonic wrote:Hey, the preamp section only need +/-15v bipolar. You could do that with a 16vAC wall wart, no problem. I designed a ring mod recently that runs on that - worked perfectly on the breadboard from a 16vAC input, half-wave rectifiers, and got a simple regulated +/-15v with some resistors and zeners.
Soulsonic is right, just look at the cheap-n-simple way the Traynor does the +/-15V.
Bye
dorfmeister
Post by dorfmeister »
Gutshot:
chicago_mike
Well I can't say I like the use of green meanies, but all in all a good build. :)
Cookie Galore?? :scratch:
Skyline FX 2013
Crumbchildz
Ampeg V4b
Peavey Bass 400
Has thanked: 18 times
Post by Crumbchildz »
Any chance of those gut shots being posted again?
Loud's a tone, right?
astrobass
Has thanked: 42 times
Been thanked: 74 times
Post by astrobass »
I'm resurrecting this, because I've decided to build one.
First off, I'm using this schematic: http://www.lynx.bc.ca/~jc/790713_TS50B.gif
And I'm taking everything up to and including the Master Volume pot.
I'm throwing together a schematic in Eagle and if anyone who doesn't suck as hard as I do at layouts would like to lend a hand, let me know and I'll at least send you the schematic file. I'm using the GaussMarkov.net libraries.
If you're not familiar with this thing, the TS-50B is the secret sauce behind the bass guitar tone on this (NSFW cover art for the "video"):
Immediate question though: the transistors and JFET in this thing are no longer common devices. AllTransistors.com tells me that the PN2907A is an equivalent to the MPS8598. To compare:
Code: Select all
					 	Mat		 Struct			Pc		 Ucb		Uce		Ueb		Ic		 Tj		  Ft		 Cc, pF	 	Hfe		 Caps
   	PN2907A	 	  Si	 	PNP	 	 0.4	 	 60	 	60	 	5	 	 0.8	 	150	 	200		8	 		 100	 	TO92
		MPS8598  		 Si		 PNP		 0.35		  60		 60		 5		  0.2		 150		 150		8			  100		 TO92
Seems like a good match, and I've got about 90 2907As already. I'm guessing just eyeballing that part of the schematic that these would benefit greatly from being at minimum matched pairs, if not all six matched for gain. Since I've got plenty to work with, I'll probably just match up all six just to be safe.
The 2N5245 on the other hand is much more mysterious. Would any N-channel JFET work there? I have a bag of J201s. What parameters should I be concerned with testing for and matching? I guess, worst case scenario, I could just build it and try some J201s and see if the world ends.
Thoughts?
Emanuele
Post by Emanuele »
what about using 2n3906? I was drawing mine with those...
Branimir
Completed builds: Fuzz Face, Small Stone, Trem Lune, Fet Muff, Big Muff (green), Fuxx Face, Son of Screamer, Rat, Rebote 2.5, Opamp Big Muff, EA Tremolo, Easyvibe, Axis Face Si, Ross Compressor, Ross Distortion, DLS
Post by Branimir »
Sorry for resurrecting this topic from way back, but - does anybody have a PCB layout for it? Thinking of trying it as a standalone preamp into a Crown slave, and if it delivers - might build a neat amp with it.
If you scoop, it sounds like poop!
Dr Tony Balls
Been thanked: 170 times
Post by Dr Tony Balls »
Branimir wrote: 02 Jun 2021, 19:40 might build a neat amp with it.
I did this for one of the Tronographic guys with a gutted pedal PCB and a Sunn/Dynaco backend:
DevouredDeth
Has thanked: 13 times
Post by DevouredDeth »
Dr Tony Balls wrote: 03 Jun 2021, 13:43
Interesting design, I have been wanting to do this with a class D I just haven't had time to layout a PCB.
