Apparently I've either forgotten how to read or how to use the search function cause I'm damn sure I found a post on this before.....
I'm looking to do a BOR clone using 2 3pdt switches...
I Wire them using http://gaussmarkov.net/wordpress/though ... p-a-1590b/.
Would I be right in thinking that I would connect the output lug on one 3pdt to the input of t'other? like in the pic below?
Brown = to effect Circuit
Green = Direct to Output/Input
Black = Not sure why I put it in...
Red = is what I'm talking about!!
Would it just be a case of connecting each effect as normal to the switch, then connect with this red bit of wire? I have somewhere something that tells me how to power it from one 9v socket too...
Thanks in advance!!
