Noob help: A/B audio switchbox w/ 3PDT + 3.5mm stereo jacks
Armchair Bronco
Post by Armchair Bronco »
Hi, first post here...and it's an easy noob question for y'all.
I want to build a simple A/B audio switchbox that has two 3.5mm stereo inputs and a single 3.5mm stereo output. I want to build something that lets me use one set of Boston Acoustics PC speakers + sub-woffer with separate inputs from my Windows 7 PC and the headphone out jack on my small 19" HDTV. Obviously, for my needs I'll be using *either* A or B but never both at the same time.
I want to use a small enclosure and 3PDT switch from Small Bear and use three 3.5mm stereo jacks from Mouser.com
Here are the parts I plan to use:
3PDT toggle switch:
Hammond 1590A enclosure:
3.5mm Stereo connector (three of 'em):
So: how do I wire this up? Let's say that the 3PDT switch has the following contacts:
Code: Select all
1 --- 2 --- 3
4 --- 5 --- 6
7 --- 8 --- 9
And let's say that the three 3.5mm stereo jacks each have contacts labeled:
Code: Select all
G (for ground)
R (for ring)
T (for tip)
Finally, let's say that two input jacks are labeled "1" and "2", respectively, and the output jack is labeled "X".
So, we have:
Code: Select all
1G, 1R, 1T
2G, 2R, 2T
XG, XR, XT
Can someone please tell me how each of the jacks should be connected to the switch? Thanks!
Armchair Bronco
Anyone? I'm just looking for a mapping like this:
1: 1R
2: 1T
3: 1G
etc.
Dr Tony Balls
Been thanked: 170 times
Post by Dr Tony Balls »
I dont know why you'd use a 3PDT. All you need is a SPDT. Wire the SPDT like so:
1: Input #1 tip
2: Output tip
3: Input #2 tip
then ground all of the sleeve connectors together, or if you're suing a metal enclosure they should ground together anyway.
If you MUST use a 3PDT, then just use one pole (column of three terminals) on it and wire it the same.
Armchair Bronco
Dr Tony Balls wrote:I dont know why you'd use a 3PDT. All you need is a SPDT. Wire the SPDT like so:
1: Input #1 tip
2: Output tip
3: Input #2 tip
On another site, someone said that I would risk popping sounds when switching between the two sources if I didn't use a 3PDT switch. I was originally planning to use a 2PDT switch as both of the build plans I found on the web for similar projects used 2PDT switches.
Dr Tony Balls
i dont see why any other switch would cause popping, or even why you'd need a 2pdt.
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
even if it pops.. it's not like you're on stage in front of a crowd.. big deal, no?
Armchair Bronco
So even with stereo audio jacks, I only need to use the connectors for the tip and the ground? You're saying I can just ignore the ring?
Dr Tony Balls
OH shit....you're right, i forgot about stereo.
yeah, you'll need at least a DPDT like so:
1 - 4
2 - 5
3 - 6
where:
1. Tip of Input 1
2. Tip of Output
3. Tip of Input 2
4. Ring of Input 1
5. Ring of Output
6. Ring of Input 2
Armchair Bronco
Cool. Someone over at OffsetGuitar.com just posted this schematic for me.
Looks like a DPDT is the way to go. Thanks for the input!
