Another Compressor!
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
This is another simple FET-based compressor. It is designed for "line level" signals, but can easily be preceded by another op-amp stage to bring the guitar signal up to 500 mV or so. If you do that, you have to follow the circuit with a volume control. A 10k log (audio) pot will do the trick.
This circuit was originally used to give final level control at the output of a pedal board (rather than for sustain), as the pedal board's output to the PA (we didn't ever use backline at the time) went through a radio link. The radio gear sounded truly horrible if it was overmodulated, so this circuit prevented that kind of distortion (I prefer the more controllable, pedal-generated kind!).
Here you go...
Enjoy.
Thanks for another great project mictester! :applause:
branleur
Post by branleur »
hum simple and easy to build! Jfet used as VDR.
:applause:
DDD
Post by DDD »
Again, too much distortion due to the FET non-linearity?
What about the half of the drain AC voltage feeded to the gate terminal of the FET?
mictester
Post by mictester »
DDD wrote:Again, too much distortion due to the FET non-linearity?
I tried it - it made almost no change whatsoever.
DDD
Post by DDD »
The mod is quite simple: just change the gate 10 kOhm resistor with the 470 kOhm and add one more 470 kOhm one from FET drain directly to the gate (National Semiconductor recommendation).
As for me, while playing with the similar circuit I've seen the great effect even on the scope.
mictester
Post by mictester »
DDD wrote:The mod is quite simple: just change the gate 10 kOhm resistor with the 470 kOhm and add one more 470 kOhm one from FET drain directly to the gate (National Semiconductor recommendation).
I tried it out earlier this evening - the distortion was reduced. It went down from ~0.6% to ~0.2%. This was measured by sending 600 mV of 800 Hz in, and nulling the output with the original. You're just left with the distortion products, and you can measure their relative levels (and look at them on your 'scope, too). The residual signal was reduced from about 3.5 mV to 1.2 mV. If you're concerned about that degree of fidelity, you shouldn't be playing with stompboxes! :)
Gerry de la Sel
Been thanked: 8 times
Post by Gerry de la Sel »
mictester wrote:This is another simple FET-based compressor.
Remarkably similar to this compressor:
http://www.seekic.com/forum/22_circuit_ ... ESSOR.html
mictester
Post by mictester »
Gerry de la Sel wrote: Remarkably similar to this compressor:
And your point is?
The simple FET compressor came from equipment that I designed and built built in the early 70s. It's simple, it works, and was copied in a number of commercial products in the years since. The only downside is that the range of control is more limited than other compression methods, but with low noise op-amps, it works quite quietly. You'll also find that the simple sidechain circuit confers a useful (though unexpected at first glance) characteristic - it tends to limit rather than compress at higher input levels.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
I reckon that, if you're using this compressor circuit with a distortion pedal after it, then the fidelity is probably going to be a moot point, so I'd agree with you.... :D
pedalgrinder
my favorite amplifier: Ampeg SVT
Completed builds: pedals with pots switches and everything
Has thanked: 198 times
Been thanked: 169 times
Post by pedalgrinder »
seems boring as bat shit this one the side chain would have a horrid response. It would be like sticking your soldering iron into a glue pot and sniffing it. Hmmm maybe that would be better
