I'm trying to use THIS x-former for impedance matching a mammoth clone's input (so I can use it w/my active basses) using Jack Orman's diagram as seen below, but using a 5k instead of a 25k trimpot based on the PC10k/10k's impedence.
My question is: Based on THIS INFO, where the hell is the primary on the pinout? (Which solder lugs to I need to connect to for the input, the CT, and the Output? I dunno if I need to use the CT, but since I have the switch I figure it can't hurt. Maybe it'll give a similar response to a soloed Jazz neck pick up but w/a more dynamic freq. response?)
Also, can I just use a pot or a trimpot instead of a switch (like a variable resistor) to select the impedance between the CT and the output of the primary, so I can dial in something more specific to meet my tonal needs? (Ct @ lug 1, primary output @ lug 3, & lug 2 into the input cap of the mammoth)
Anyway, can someone please help me figure this one out?
Thanks for your assistance.
