[Tagboard] Ross Compressor
Hi, here we are Ross Compressor based on Tonepad layout. Please take it as a joke! It's huge as fuck, so only fully insane person will consider to build it... Build an amp instead :D That will take less space ;)
Here is the link to tonepad with this project files, also check out "build report" section for even more info and mods
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Jaysus! [smilie=a_holyshit.gif]
Well done that man!
[smilie=a_bravo.gif]
:D Thank you, I knew you'll enjoy it ;)
johnnyg
Has thanked: 92 times
Been thanked: 43 times
Post by johnnyg »
You must really love the Ross Compressor Pawel! :D After all the effort of making a layout I expect you to build this! :wink: You'll probably need a pretty big enclosure... one carved from a block of solid mahogany to help with the tonez... :blackeye :P
Never gad a chance to build one really :D
On circuitworkshop.com IvIark hit me with idea of using 1U rack space enclosure... Probably I'll scrap it anyway and I'll start from beginning with Baja's optical compressor ;]
Now I can go to bed :)
Here we have V.2 of this layout... You may call it "compact" ;) as it's two tag less, also I have changed things around Q1 to keep transistor in line... the rest is the same, and it's here to stay as it is.. I have no plans to mess around it any more
If you anal to tagboard builds like me, keep refreshing FSB board today, it's something very special coming :)
