Page 4 of 4
Re: EMG DG20 (SPC and EXG) schematics etc.
Posted: 14 Aug 2021, 09:03
by bajaman
Hi folks
I was recently asked for fab house files for some of these boosters and realised I did not have anything to offer because the original artwork was done in CorelDraw and not a recognised PCB artwork package. I spent a few hours with the excellent Sprint Layout 6.0 ( if you are not familiar with this program I strongly suggest you check it out ;-) ), and now i am happy to post some images for the smd files for the DG20, SPC,and RPC boards as well as through hole versions for SPC and RPC. Most fab houses require gerber files, and these are listed below. I am happy to supply the Sprint Layout 6.0 files upon request - just PM me if you need them. In the meantime here are some gif images and gerber files exported from the Sprint Layout 6.0 files. Kindest regards to all and hope you are getting through this awful seemingly neverending covid pandemic safely :wink:
cheers bajaman
Baja buffered DG20 SPC and EXG smd 130821 bottom layer.GIF (11.36 KiB) Viewed 4616 times
Bajaunbuffered RPC smd 130821.zip
(7.29 KiB) Downloaded 186 times
Baja unbuffered SPC through hole 130821.zip
(9.06 KiB) Downloaded 175 times
Baja unbuffered SPC smd 130821.zip
(6.91 KiB) Downloaded 172 times
Baja unbuffered RPC through hole 130821.zip
(9.38 KiB) Downloaded 465 times
Baja buffered DG20 SPC and EXG smd 130821.zip
(14.81 KiB) Downloaded 198 times
Posted: 15 Aug 2021, 03:01
by bajaman
Here are a few more ....
Baja buffered SPC smd 130821 top layer.GIF (27.66 KiB) Viewed 4559 times
Baja buffered RPC smd 130821 top layer.GIF (27.88 KiB) Viewed 4559 times
Baja buffered SPC smd 130821.zip
(7.81 KiB) Downloaded 190 times
Baja buffered RPC smd 130821.zip
(8.17 KiB) Downloaded 184 times
Posted: 15 Sep 2021, 09:06
by uberNick
Hello guys!! Ive stumbled on this Forum post searching for an solution for a problem with the new DG20.
I want to make my "ULTIMATE" Partcaster with the new DG20 but I plan to replace the switch with 10-Way Freeway Blade Switch...
My problem with it is that the new DG20 has the PCB mounted and i am not that knowledgable in electronics as the EMG instruction specifies that EMG pickups dont need the Groundwiring and the Freeway Switch Wiring diagram has contacts for ground and hot... If its not possible via DG20 PCB, i am willing to buy the pickups and exg and spc separately to do that modification.
I just need your assistance on this matter as you guys are much smarter than me :lol:
Posted: 28 Sep 2022, 17:55
by spoontex
what type of potentiometer is designed for? Bourns, Cts, Alpha... ? As well the first design smd version ( buffered ) in the page 1.
Posted: 22 Jan 2023, 02:46
by finebyfine
Hello! Could anyone please share the schem for the RPC? I see the pcb layouts but can't find the schematic for it
Posted: 23 Feb 2023, 07:25
by zfrittz6
Hello, what is the correct installation order for SPC, RPC and EXG?
1-RPC-SPC-EXG-OUT, or
2-RPC-EXG-SPC-OUT
