Can I cut my IC sockets to size?
Swervedriver
Post by Swervedriver »
If I cut these sockets I have that are to large into 14 and 8 pin sockets will they work? Is each socket pin separate from the other, or are they all connected?
salocin
Been thanked: 7 times
Post by salocin »
The pins are not attached to each other, so go crazy!
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Yep, you sure can. I've done it plenty of times. Got a good deal on 16-pin sockets, but I use 14-pin ICs more frequently.
grievousangel
Post by grievousangel »
Check these out: http://www.taydaelectronics.com/servlet ... Categories if you find the cutting doesn't go as planned.
