take the shitty caps out of a wah wah pedal and put high quality orange drops in - you WILL hear a difference in the sound, unless you are deaf
A friend of mine recently replaced the cheap shitty mylar greencaps in his later model Les Paul - I gave him some Sprague Orange drops to try - he heard the difference and found the tone controls much more even in use.
I am not trying to justify MOJO - just stating FACTS - some components sound different to other components, even from the same manufacturer
If you still do not believe me try replacing the BS170 in your SHO pedal - you may have to try 3 or 4 from the same batch until you find one that SOUNDS right
Even different 12AX7 / ECC83 vacuum tubes SOUND different to mine and my customers ears.
I once put a set of Groove Tubes JJ type preamp tubes in a customers Fender Hot Rod Deville combo - he brought the amp back to - said he had to turn his treble way down to compensate for the extra brightness over his Russian Sovtek 12AX7s previously fitted. The solution was to put a set of Chinese 12AX7C Groove tubes in his amp - he LOVES the SOUND of his amp now, compared to with the JJ type - same tubes but different SOUND
Electronic theory and computer simulated modeling can take you so far, BUT at the end of the day your ears will have the final say
