Changing to a higher pot value won't help because maximum gain is achieved with the Drive pot at zero.floris wrote:The gain is mainly set by the ratio of the feedback resistor, between opamp output (pin6) and the opamp minus input (pin2), and the resistor between opamp minus input (pin2) and ground. Google for "non inverting amplifier":
http://en.wikipedia.org/wiki/Operationa ... _amplifier
So:
Make the 100k feedback resistor smaller (R7 in the schematic of analogguru if I'm not mistaken).
Or make P1 drive pot larger.
If you want to make the higher Drive settings unavailable, there's a resistor in series with the Drive pot that you can change, or there's the 100K Feedback resistor that floris mentioned.
