Crowther Audio - Hot Cake Overdrive [traced]
- briggs
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
It is there for protection - in case some clown plugs in a higher voltage supply - they are out there - trust me on this one folks
It then clamps the dc voltage to 8.2 volts and provides stable operation from the circuit
Steve
Steve
The schem is an older version w buffered bypass.
The HC was slightly altered over the years (I know at least 8 different versions w true and buffered bypass).
This version sounds very good, but maybe, depending on the trannie HFE, the values of the Zener diode must be slightly altered (+/- 25%) to get it sound right.
I prefer the new tone pot version, 'cos it can produce all inbetween sounds ( w the pot fully closed and fully opened you'll get the 2 sounds of the switch version).
JHS
JHS
- bajaman
Hi JHS
Yes - but the old ones sounded more warmer to my ears because of the 741 and it's lousy high end response - sometimes good top end is not necessary, especially in distortion devices
Steve
Steve
- briggs
- bajaman
Try an NE5534 or OPA134 instead of the TL071
- analogguru
- bajaman
XLF - extra low frequency - probably increased the feedback and coupling caps - BTW, it's the green led that gives it that Ka ching sound
Steve
Steve
Just built this per the Torchy layout. Thanks man, turned out great. Tried out a bunch of different opamps as well; TL071 is the best to my ears, but the 741 is harsher in a nice way. A little more compressed, I think. The two sounded pretty good in parallel, but not good enough that I thought it was worth the headache.
Carl
Carl
- bajaman
Hi bluetoad
Did you connect the additional 220k resistor from the inverting input (op amp pin 2) to the half rail voltage point, when trying the 741
Try it
Steve
Try it
Steve
- soulsonic
I wonder what an LF411 would sound like in it? I guess I have to build one now too.
- Goop_buster
I only had a TL072 (half from) when I tried this out according to one of the older schematic.
I expected to hate it
but when I plugged it in I could not believe how good a single OP-amp could clip
Nice circuit. Well worth the effort to try out and experiment with
- bajaman
Come in Bluesberry degooper
- bajaman
Probably the 10k, 82n and 1k
try different values here for different responses
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
Building this now and only have a 8.2V zener or a 9.1V, check the datasheet for the original 1N5238 and it says 8.6V. AG's schematic give an alternative zener which IS 8.2V so I guess this is ok.
I read this thread with some great comments by JHS, but it doesn't tell me much about which value of zener and why.
https://www.diystompboxes.com/smfforum/ ... ic=50807.0
Maybe JHS could you replace that dead link?
thanks
thanks
