Compression Sustainer
- mictester
This is a cheap and simple circuit that was developed a few years ago for a series of commercial products. Unfortunately, the manufacturer got out of effects just as this was to go to production...
The prototypes of this sounded truly amazing, and the range of control was better than many similar products. This was to be just part of an effects system - the output of this module would (for example) feed a three-band tone control.
We compared this unit against the MXR Dynacomp, the Orange Squeezer and the EH Soul Preacher. It didn't have quite as much "squish" as a Dynacomp but in "compress" mode, it was quieter and less distorted. It beat the Soul Preacher and the Orange Squeezer in every way!
You'll notice that component values are frequently repeated, and in some cases are used in parallel to get the values we wanted. Obviously, you can replace (for example) the 1uF // 1uF in the timing filter by a 2u2, and the 2M2 // 2M2 with a 1M. It's just much cheaper to bulk-buy a smaller range of components!
I've got a PCB layout somewhere - I'll post it here in a day or two. There's also the prototype Veroboard layout which I'll post too.
Have fun!
Have fun!
- mictester
Yes. The rectified DC from the uppermost diode is below zero Volts (to drive the FET into conduction) so those filter capacitors have to have their positive plates to the ground rail!Brink wrote:Looks interesting.
Are the top left two 1uF caps supposed to be oriented that way?
- Brink
- Degoop Doctor
Here's my current vero, which is untested.
I'm somewhat unsure about which which pot lugs to use.
admin edit: see updated version viewtopic.php?p=90578#p90578
Reason: deleted preliminary schematic
- RnFR
well i see 7 1u caps in the schematic, and there are only 4 in your layout. also i don't see a 2u2 cap in the schematic, and you have one in the layout.
- mictester
I'll post a vero and a PCB later today!Brink wrote:I built up that vero of mine. It doesn't work. It could be my soldering skills, or I'm wondering if I got the transistor orientation correct.
- Brink
- Degoop Doctor
The 2u2 was to replace 2 1u in parallel (same with a 1m vs 2x 2M2). That only account for 6, though. Looks like I forgot some components.RnFR wrote:well i see 7 1u caps in the schematic, and there are only 4 in your layout. also i don't see a 2u2 cap in the schematic, and you have one in the layout.
- jstbrowsin
- Grease Monkey
Hi there I'm really interested in this circuit.. . when will you be posting the PCB please?
kev01 wrote:This one wins the gooooooooooop award. That has more silicone than Pamela Anderson.
- jstbrowsin
- Grease Monkey
Bump
- jstbrowsin
- Grease Monkey
Yeah I'd love to, however although I have completed successfully a few projects from this site (Orange Squeezer and two xotic boosters) I'm relatively new to this game. Sort of a paint by numbers guy if ya know what I mean. I have just started L2 & L3 electronics engineering if that's any consolation so I hope to be able to contribute quite a lot more towards the end of the year but for now I'm a noob.
I didn't mean to ruffle any feathers. I noticed in the previous post that a pcb was going to be posted that day and just thought I wonder what happened to it?
This post wasn't intended to put pressure on anybody here sorry if it came across that way.
- my favorite amplifier: Musicman 210-65
- Completed builds: BYOC 250+
1-Knob Fuzz
Orange Sunshine
Fuzzy Elephant
Master Volume SHO
Before I dive into this, has anyone verified the vero layout? Since my skills are still in the newbe stage and all I have for 1uf caps is film just want to have a reference point to say this should work.
Thanks,
John
Thanks,
John
Wow - do I get this right? The compressor works by varying bias between the signal amplifier's +/- inputs rather than fetshunting the signal itself?
Resident PCB department evil for DIY
- mictester
No! The FET varies the resistance "to ground" from the non-inverting input of the op-amp.livingnote wrote:Wow - do I get this right? The compressor works by varying bias between the signal amplifier's +/- inputs rather than fetshunting the signal itself?
