swap non polarized for polarized in MXR Noise Gate???
trad3mark
my favorite amplifier: Vox Valvetronix Series
Completed builds: Super Hard On
Fuzz Factory
Aenima/Torn's Peaker (2 in 1 box with toggle switch)
Valvecaster Deluxe (Boost before VC)
Proco Rat (Mod to power jack, and input cap changed)
87% PillowStone
87% GlassJaw
Post by trad3mark »
Hey all,
I'm planning on building this: http://www.tonepad.com/getFileInfo.asp?id=77
I have everything EXCEPT the 1uf NP. In this schematic, is it possible to either a) use a polarized one? or b) replace it with a lower value (0.47uF is the closest i have.)
cheers,
tm
NickS
Post by NickS »
I think it's best to stay with NP. I would use 2 x 0.47 in parallel.
trad3mark
Fuzz Factory
87% PillowStone
87% GlassJaw
Post by trad3mark »
or two 2.2uF electrolytes back to back in series? But do i go - + , + - or + -, - +?
NickS
Post by NickS »
There's no reason why it should matter. My only concern is that unlike in speaker crossover circuits, another common application of "bi-polar" electrolytics, where you can be sure that there is no net voltage across the capacitor when there is no signal, the quiescent state of this circuit will be 0.6V-0.7V positive at the transistor end. When signal is applied, the transistor base-emitter junction should act as a rectifier, causing the transistor end to go negative temporarily. If you want to try a single electrolytic, I would put the positive at the transistor end and the negative at the 22K resistor end.
trad3mark
Fuzz Factory
87% PillowStone
87% GlassJaw
Post by trad3mark »
cool. i'll try them both. cheers.
mwynwood
Post by mwynwood »
I'm building theTonepad Gate at the moment and was wondering the same thing.
I don't have a 1uf NP - what did you guys find worked?
G'day, I'm Marcusmwynwood.comPictures of my Builds
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
MXR had a 10nF capacitor there :secret:
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
NP is misleading imho, because everyone thinks they have to find a NP electrolytic. Any cap will do that's not a polarized one. Just use a wima cap or the likes.
