Where can I find these pots?
Posted: 06 Feb 2010, 09:42
by nbabmf
They're made by Alps, but I'd be down for a similar made by Alpha, etc. I could lose my mind looking through Mouser online.
I figure at least one of you guys has repaired an Ibanez L series or 10 series pedal...
Re: Where can I find these pots?
Posted: 08 Feb 2010, 18:00
by Dirk_Hendrik
and ran into the same problem...
Posted: 08 Feb 2010, 22:27
by Jaicen
What values are they? You can find those pots in all manner of Boss and Roland gear from about 1981 onwards. For example, the TR-505 has a 1M Reverse (!?) Log and a 100k Lin pot.
Posted: 09 Feb 2010, 02:25
by salocin
Just got some rotary encoders today which look nearly identical. Not that it helps, sorry.
I do however have a non functional DDL at home which from memory still has the pots. Depending on what value you're after I may be able to help.
Posted: 09 Feb 2010, 07:28
by nbabmf
The rotary switch that selects the modes seems fine, but the 3 pots are all dirty and with wobbly shafts. They've all been out drinking together, obviously.
(2) 100kB
(1) 10kC
I must say, if you don't mind all the weird noises that occur when you turn the pots and the delay repeats that pitch shift for a bit before settling back into tune... it's awesome! Digital effects behave so strangely when things aren't perfect.
Posted: 09 Feb 2010, 23:24
by salocin
I was wrong sorry, I only have the switch left on there.
Posted: 10 Feb 2010, 11:13
by nbabmf
I appreciate you looking!
