Here is a little circuit snippet that I have been using for some time - it eliminates the need for a triple pole switch and provides a very high input impedance (so you won't lose tone)AND a very low output impedance for driving other effects following.
ALSO - you will never be plagued by that switching pop that you get with most true bypass schems - this baby is virtually NOISELESS and transparent.
The circuit is by no means original - but you can stick it in front of any effect you like and enjoy noiseless non tone sucking nirvana
Just about any n channel jfet will work - I just have a real soft spot for the 2SK117 - call me sentimental but I really like these Toshiba jfets, and I am not the only one who does.
Do not ask for a layout - I usually build it on a very small piece of veroboard - you should give it a try yourself - it is not that difficult to do
Enjoy
BAJA n channel jfet buffer
ps: if your effect does not have a suitable half rail voltage (4.5v with 9v circuits), then just use two 100k resistors in series, strung between the 9v rail and ground. Then connect the 1M input resistor to the junction of these two resistors and voila - all done
