Really Cheap Compressor  [documentation]
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Do you remember the old-fashioned way of doing bass compression? It used an LDR across the volume control illuminated by an incandescent lamp across the speaker terminals! It was a simple method back in the 60s....
This compressor is almost that simple! It uses a handful of cheap components (I built one for £9 including hardware!), but works really well. Guitarists who've tried it often ask "Is it on?", but miss it when it's off! It's quiet, and has good "squeeze" without the gain-change artefacts you frequently get with transconductance amplifiers or FETs.
Really_Cheap_Compressor.zip
(56.22 KiB) Downloaded 1972 times
The LDR should be ~1M in the dark, but almost anything will do.
Some of the component values are quite carefully chosen. The input capacitor (15nF - made up of a 10 and a 4.7 if the 15 is unavailable) is chosen to give some frequency shaping, and the interstage capacitor prevents handling noise affecting the compression. Green LEDs are chosen because they most closely match the response of the LDR, but yellow works almost as well. Obviously, the LDR / LED combination should be facing each other, and must be in a light-tight enclosure.
Bypass switching can follow your favourite scheme - my prototype has a "Millennium Bypass" and an externally mounted blue LED to shown when it's on - and the input pull-down resistor prevents switching "pops".
Enjoy!
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
really NICE Compressor :thumbsup
thank you
borislav
mictester
Post by mictester »
borislavgajic wrote:really NICE Compressor :thumbsup
thank you
borislav
Thank you! I've built three of them, kept one for myself, one for my nephew and sold one to a famous player who tried mine in a studio and said "I WANT ONE!!". I'm thinking of getting some boards etched, as this could become a regular build.
CRBMoA
Post by CRBMoA »
I am waiting on some LDRs. I can't wait to try this!
Looks great!!!
atreidesheir wrote: Let's build some damned pedals!
Brink
Been thanked: 18 times
Post by Brink »
I designed a PCB. At 1.5"x1.5" it would easily fit in a 1590B.
Comments? How does the LED/LDR spacing look?
Mictester Optical Opamp Compressor.GIF (13.43 KiB) Viewed 19698 times
Brink
Post by Brink »
Mictester, I assume that sustain pot lugs 1 and 2 connect to the opamp output, and the you turn the knob clockwise for more sustain. Is this correct?
mictester
Post by mictester »
Brink wrote:Mictester, I assume that sustain pot lugs 1 and 2 connect to the opamp output, and the you turn the knob clockwise for more sustain. Is this correct?
Correct. Basically, you can just connect the wiper ("pin 2") and the end so that as you turn the control clockwise, you increase the resistance (you're actually reducing the amount of negative feedback around that second op-amp so the gain increases).
mictester
Post by mictester »
Brink wrote:I designed a PCB. At 1.5"x1.5" it would easily fit in a 1590B.
Your board layout looks good. I normally bend the LED legs so that one is "stacked" on top of the other, with both facing the LDR. Your spacing is fine.
Remember - for it to work properly, it must be dark around the LDR / LED combination. To test it outside its box, I made a temporary tube of black insulating tape. It worked OK, but was better when I put it inside an Eddystone diecast box!
dune2k
Completed builds: Fuzz Face, Catalinbread SFT, Proco Rat, Bazz Fuss, EHX Muff Fuzz (Transistorized), Hjart Müller Bass Drive, Demeter Compulator
Post by dune2k »
If I want to use this comp for bass guitar, would I need to change something?
JOHNO wrote:P.S Great pedal for playing 70's porn music.
mictester
Post by mictester »
dune2k wrote:If I want to use this comp for bass guitar, would I need to change something?
Yes. The frequency response is set up for guitar. To make it OK for bass, you need to (basically) double the values of the capacitors, so that the response goes down an octave. The changes you need are:
The input capacitor needs to be a 33n (from 15n), the coupling capacitor to the second op-amp needs to be a 220n (from 100n), the electrolytic feeding the LEDs should be a 2µ2 (from 1µ), and the output electrolytic should be 4µ7 (from 2µ2).
I've just tried it on a breadboard, and it works well with my Fender Precision!
dune2k
Post by dune2k »
Nice, thanks!
Gonna order the parts soon & will get you posted.
I also made a perfboard layout for the guitar version today and will post it soon. (Gotta check that everything's ok.)
dune2k
Post by dune2k »
Haven't checked, nor built it yet. So everything is still unverified.
(Sorry for the load of jumpers+possibly wired backwards pot, it's my second perfboard layout.)
Unverified!
Unverified!
Unverified!
Unverified!
viggersster
Post by viggersster »
hey, i am ordering the components to build this pedal but i am having some trouble finding the LDR with the right value. any suggestions?
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Most LDRs are ~1M in the dark, where are you ordering from?
And mictester, if you do end up ordering a bunch of PCBs, would you add one to the order for me? :)
YuGi
Been thanked: 25 times
Post by YuGi »
Hides-His-Eyes
looks spot on to me.
YuGi
Post by YuGi »
Hides-His-Eyes wrote:looks spot on to me.
Sorry, what do you mean? My english is not very good :oops: :slap:
mictester
Post by mictester »
He means that the part looks exactly right.
You're going to learn a lot of colloquial English on this board! :) ("Spot On" = "Exactly Right") :thumbsup
YuGi
Post by YuGi »
mictester wrote:You're going to learn a lot of colloquial English on this board! :)
Yeah I like this board! :applause:
Thanks for the compressor, I will try it as soon as possible :D
sevinisthenumber
Been thanked: 29 times
Post by sevinisthenumber »
You have a PNP trace image?
C.S. Lewis
