But, back to your design. Another question: why germanium diodes? For the knee curve or voltage drop? Could it be substituted for a silicon? or a led?
For the knee curve of course. this is why four diodes give better results than one. Silicon gives less dynamic resistance dV/dI near zero currents. Maybe leds, but leds have higher voltage drop.
Also, I attached the "auto-bias" stage (that's what I meant in my previous comments). Ideally, the current-setting resistor in the source "CCS" circuit would be chosen so that the voltage on the drain resistor would be the "right one". Again ideally, different fet's Vgs spread would be compensated by the source-biasing circuit.
I already wrote that current stabilization is bad for sound in this case.
We need only set up initial current (drain voltage). Don`t forget - we already have DC local negative feedback by source resistor.
Latheral mosfets have less Vgs spread than other types due to their structure.
If you prefer constant resistors - replace trimmers after adjusting.
I think it will be enough to do it once for each stage design.
I use trimmers because constantly experimenting,
