One of the problems with Blues Juniors (as reported on Bill M's site - and probably elsewhere) is hum, induced into the output transformer by the nearby mains transformer.
Bill M shows a simple mod with a folded piece of metal (he didn't specify what metal) between the two transformers (
http://billmaudio.com/wp/?page_id=882).
I've got a Carling On/Standby/Off switch fitted to my BJ, and as soon as I go to standby, there's noticible hum coming out of the speaker. So I thought I'd try Bill's simple mod. Aluminium didn't seem to do the trick - but the steel (?) bottom off an old, unloved Boss pedal worked wonders !
I decided to make it a permanent fixture, by stripping off the rubber 'foot', drilling a 4mm hole in the centre of one end of the plate, then bending it in a vice.
The part with the hole, I made about 10mm wide - and this bit fixes under the nut of the output transformer. I bent the plate upwards, about 90 degrees from there, to the approximate height of the transformer (as Bill recommends), then on a downward slope towards the mains transformer. For a photo, visit Bill's site - my plate is similar - but much neater.
It doesn't remove every trace of hum, but it certainly reduces it to a more acceptable level. Definitely worth a try if you've got a hummy amp.
