I sure don't quite understand how to remove the buffers and switching system. It would be cool to build a clone and tweak it. This was always a cool design.
Yes, it certainly looks like they are an essential part of the circuit, even if the FET switching is changed to something else. The input buffer is a nice high-Z JFET too.Dirk_Hendrik wrote:Why would you remove the buffers???
mmm.. since I'm a newbie at all this and don't feel like wrestling with a relay right now, I might as well leave the pedal on all the time and switch it On and Off with what would be a true bypass looper box system except that it would be in the same enclosure than the pedal circuit...soulsonic wrote:As Dirk mentioned in another thread some time ago; a clever person would use the existing soft switch/flip flop circuit to drive a relay for true bypass. I think that's a great idea, and I'd like to experiment with it myself. It would be a much better solution than hacking up a perfectly good pedal.Dirk_Hendrik wrote:Why would you remove the buffers???
dread pierat wrote: (which is a modified Univox Superfuzz clone)
Because in my opinion the business end of the FZ-2 - the octave and clipping section - is pretty much identical to the Univox, and the voicing of Fuzz I is similar to the notch switch on Superfuzz, only with a higher notch frequency and a little more treble rolloff. Then BOSS added the Fuzz II channel with a different voicing, the (maybe superfluous) Boost option, and a pretty nice tone section. Is this really enough to turn "super" into "hyper"?RnFR wrote:why, because it's got a differential amplifer? i'd say the two have MUCH more that is different than they do alike. you would hardly be able to modify a superfuzz into an FZ2, you'd be much better off just building one from scratch.
Any chance you can point the ignorant (me) in the right direction on how exactly to do this?dread pierat wrote:to mod an FZ-2 into a convincing Superfuzz all you need to do is change one resistor and one capacitor, jumper another resistor, cut another capacitor, and move the level pot and output to the 1k resistor after IC1a. Then change the diode clippers, and you should be good to go.
Hi people! I recently acquired this fz-2, As I searched through google, I landed here and pointed me to you! I am reviewing your advise about modifying this fz2, @dread pierat(hope you are still here!) though you gave a snap shot of the pcb of the fz-2, you somehow still left us half-blinded, to which parts to be jumpered,cut ,replaced...dread pierat wrote:To mess up your valuable pedal all you need is to reference a Superfuzz schematic and alter the highlighted areas in the attachment accordingly.
Clippers: D4,D5. Change to some nice germaniums.
Notch filter: Cut, replace and jumper.
Then move the output to the output of IC1a.![]()
