Timmy PCBs for sale
- Brink
- Degoop Doctor
I have Timmy PCBs. They use a 3 position (on/off/on) SPDT switch instead of the internal DIP switches.
Layout: http://imgur.com/KNL46.gif
Fits in a 1590B.
Has some extra room in the clipping section if you want to experiment.
$8 USD each with free shipping.
Yes, I'll ship them to the US, UK, Europe, Japan, Australia, pretty much anywhere.
PM me or, if you prefer, use http://boardshop.weebly.com/.
Fits in a 1590B.
- IvIark
PM'd
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
Is those the same I got from you last time?
BTW - quality of your PCB's are top of the tops!!!
- sinner
Hi, I've asked you a question via PM, but it was ignored by you, so again witch pads are for switch, and witch are for treble pot?, also what kind of toggle I should use?
Pawel
Pawel
- IvIark
Just use a SPST mate, the connections are marked on the layout, 1 2 and 3 directly below "Switch" on the layout.
- sinner
You're my princes
so Treble takes only pad 1&2?
- IvIark
Treble 2 and 3 are linked
- sinner
- IvIark
Pawel I just realised I wrote SPST, but it obviously needs the changeover type with 3 lugs, SPDT. That'll teach me to post with my brain out of gear.
- IvIark
Of course, I never only order one of something!
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
are these verified to the schem
http://3.bp.blogspot.com/_y4AYtND8Hz8/S ... am2ed5.png
just that I don't see the 3K3 going to pin 2 of the drive pot is all.. my schem kung fu is weak though.
or is that schem wrong?
and the switched diodes seem different too?
the schem shows only 6 X 1n4248 in total, but there's 7 here...
i'm interested. anyone have any spares?
