MXR - Auto Q  [schematic]
Has thanked: 235 times
Been thanked: 908 times
Please let me know. Reversing is no option as I'm running toward a deadline. Will sign a NDA without a problem.
fosnal1950
Post by fosnal1950 »
Do you mean this one ?
Alf
Thanks.
But I'm referrin to the new one which has been bitching me for a full sunday and, though improving from completely dead to less dead (does bypass again, does do audio in affect mode again), to "does not do envelope effects yet". Although there's similarities to above schem the new one has a lot more junk under the hood.
n8b5150
Been thanked: 7 times
Post by n8b5150 »
A customer brought one to me that wouldn't pass signal, but Dunlop was no help and wouldn't give up a schematic. They had a $50 flat fee repair (this was about 2 years ago), so I had the customer send it to them. Not sure if this is an option for you.
Bernardduur
Has thanked: 97 times
Been thanked: 850 times
Post by Bernardduur »
Dirk_Hendrik wrote:Thanks.
Checked out my DisumBOMBulator scheme? It is similar to the old MXR with some add-ons and more 'junk'.
Maybe it helps
Thanks again.
I think I've got the bitch covered. Step 1 was no power. A burned 10 ohm resistor in the power line. Step 2 a dead 4049 (SMD naturally). Replaced and she could switch in and out again. Did filter but no quack, let alone wah. Replacing 2 Motorola TL074 like chips by LM324's made her quack again but rather distorted. I expect the replacements with real TL074's will do the trick.
No TL074's in tha house??? Plenty... but not in SMD... which I did for LM324's... :oops:
borislavgajic
Has thanked: 131 times
Been thanked: 281 times
Post by borislavgajic »
no doubt you are going to fix that....... :thumbsup
boris
pz
Been thanked: 52 times
Post by pz »
Does the new pedal still use PWM for the variable resistances?
I remember, while experimenting with PWM on my breadboard i used once LM324s and got ugly distortion (the chips were ok), which disappeared when i replaced them with 074's.
074 is a good chip :thumbsup
pz wrote:Does the new pedal still use PWM for the variable resistances?
yep.
The 324 is made for a single supply. The TL's, like most opamps for a dusal supply. Hence the ugly distortion when using them in place in a circuit with a virtual ground, like almost any 9 volts effect.
Ice-9
Has thanked: 134 times
Been thanked: 363 times
Post by Ice-9 »
Sorry to resurrect an old thread but I was wondering if anyone managed to find a schematic for this (M-120 Auto Q). I have one on the bench now for repair. It is in a poor state after someone tried to repair it with very bad soldering around all the IC's. I have got it switching but the output signal is very low. I'm just going to go through the signal path with an audio probe but a schematic would really speed things up if there is one.
