What to do with IC's from Peavey Stereo Chorus 400?
Posted: 25 Feb 2010, 05:03
by evanc521
I have a whole bunch of IC's from an old Peavey Stereo Chorus 400 and I'm wondering if anyone has any good ideas for using them!
Here they are:
8038CP 8516
RC4558P
084CP 8512
MN3007 46
RCA 501
Re: What to do with IC's from Peavey Stereo Chorus 400?
Posted: 25 Feb 2010, 05:54
by Duckman
Use the search function and some of this buddies will appear (at least 4558 and 3007)
Follow those projects and you'll get a lot of info to work.
Posted: 25 Feb 2010, 06:04
by mictester
evanc521 wrote:I have a whole bunch of IC's from an old Peavey Stereo Chorus 400 and I'm wondering if anyone has any good ideas for using them!
Here they are:
8038CP 8516
RC4558P
084CP 8512
MN3007 46
RCA 501
From the top:
The 8038 is a function generator IC - quite expensive these days. It's a Voltage Controlled Oscillator with sine, square and triangle outputs. You could use it as the modulation oscillator for a tremelo, and use the different wave shapes for quite different sounds.
The 4558 is the cheap, generic dual op-amp used in Tubescreamers.
The 084 is a quad FET input op-amp. Use it in a circuit that needs four op-amps!
The MN3007 is the "Bucket Brigade" Delay IC. Build a Zombie Chorus or a Clone Theory Chorus - it's used in both.
I'm not sure about your RCA 501 - is that all of the markings?
http://www.datasheetcatalog.com/ is a superb resource, and you can find all this out for yourself easily!
Posted: 26 Feb 2010, 06:01
by evanc521
Cool, Thanks! This'll be fun
