EMG Active Pickup Circuit?
EddieTavares
my favorite amplifier: marshall
Been thanked: 25 times
Post by EddieTavares »
askwho69
This circuit is a voltage gain amp like MXR microamp, see the ground signal next to the first 1uf cap, it's not a differential preamp, if you intend to use this as a internal booster maybe it work, but we have much better optional circuits like EMG PA, tillman, tens of jfet and mosfet boosters.
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
:horsey: cheers.
happy helloween
ACTIVE PICKUPX6 PNP.pdf
(91.65 KiB) Downloaded 920 times
ACTIVE PICKUP LAYOUT.pdf
(11.65 KiB) Downloaded 720 times
ACTIVE PICKUP SCHEM.pdf
(11.94 KiB) Downloaded 1055 times
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 75 times
Post by Jarno »
Nice! Did you try it already?
Going to a SOIC opamp could shrink this down even further (and is still somewhat possible to handsolder).
rasta_maleek
Jarno wrote:Nice! Did you try it already?
Yes, i did it no vero board. But i got some time to do it on eagle cad
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
someone has schematic Seymour Duncan Modular preamp?
HULISRAKA
Post by HULISRAKA »
HULISRAKA
Post by HULISRAKA »
I have a few questions.
how we can modify the circuit to produce different sounds, such as the single-coil? The coils are connected in parallel, so it's not quite humbucker. What sound we get using the stack-humbucker(humcanceller)?
EddieTavares
HULISRAKA
If you want to use the emg circuit that is a basic differential preamp the "Secret" to achieve a more single coilish tone is to use unbalanced input gains, eg: 5db in the non inverting input and 8db in the inverting input. The more unbalanced is this relation more noisy, trebly and single coilish would be the tone.
But you have to know that this activated pickup will never sound exactly like a single or real humbucker. I tried it with a dimarzio Virtual Vintage solo and it sound great but nothing about real single coil.
andregarcia57
I have one on my guitar JB / seymour jazz kit
I read that Seymour Duncan Livewire Dave Mustaine Active is the same kit that only active, most found nothing about
Anyone know of some schemematic?
HULISRAKA
Post by HULISRAKA »
I do not know how true this is , but there is a scheme for single-coils http://guitar.ru/articles/pickup/sound-pickup_318.html
EddieTavares
HULISRAKA wrote:I do not know how true this is , but there is a scheme for single-coils http://guitar.ru/articles/pickup/sound-pickup_318.html
Is this what you mean?
It's ok. It works but all emg pickups are dual coil staked or humbucker design.
HULISRAKA
Post by HULISRAKA »
no,
this
EddieTavares
It is the same circuit with a tone shaper.
HULISRAKA
Post by HULISRAKA »
I will try to explain what I mean. For example, I'll use a preamp with hum canceling pickup (stack-humbuckers). It will sound like blackout humbucker. Because the preamp is not configured to sound like a single-Coil
HULISRAKA
Post by HULISRAKA »
On the other hand, EMG s/sa have preamplifier configured differently. And it will not sound like a humbucker, even if the coils are arranged horizontally
EddieTavares
Active pickups are always actiive humbukers. I like the way that they sound but you will never get the classic tone with those, they are silent and they have a perfect tone, I think that they are excessive perfect.
HULISRAKA
Post by HULISRAKA »
Yes, I Agree that, active pickups are perfect. And better than passive hambuckers. but Emg sa and standart emg humbukers has diferent frequency response
rcustoms
Has thanked: 363 times
Been thanked: 518 times
Post by rcustoms »
hi folks
last days some customer send me a fake EMG pickups(chinese versions of 81 and 85 models),that really sound very bad ,a microphonic noise issue .and tell me that do some magic with this pieces of s....., ok i will try but i don`t made miracles.
let`s open those units ,with my mototool y cut very carefully the black epoxy resin and find this:
and see ,looks like new version of the preamp. maybe the real EMG circuit?or maybe chinese mod?
the most particular think,the big rectagle with the center hole and 470k resistor marked as RX .for what purpose? this rectangle fits exactly with the magnet .let me do some wire schematics
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Post by rcustoms »
a quick schema
Honeyview_2015-11-18 22-34-23-1.jpg (29.25 KiB) Viewed 4400 times
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
rcustoms, can you measure the capacitors and the resistance of the coils?
