Giannini - FZ-110 Axcess Fuzz
Alex Frias
Been thanked: 14 times
Post by Alex Frias »
Well... it's from a new line of guitar pedals this brazilian company is distributing for cheap.
I have one in my hands, so I tested it and after some playing with it I devided to open it to know its guts.
It's a Belcat fabricated one, as I saw in the PCB, FUZ-520. It looks like a OpAmp (uA741) with red LED's at the output for clipping. It has a J201 too. The footswitch is a miniature 3PDT. I didn't dislike its sound, but unlike my beloved fuzzes, it does not clean the guitars sound when I lower the volume pot on my guitar, as a good Ge Fuzz Face does with elegance.
Some shots:
I think if I could do some improvement on this thing, I like it anyway, very crude and the constructions is good.
bool
Post by bool »
Perhaps it would clean better if you solder a loading resistor across the input jack gnd and hot pads. (maybe use a 100k trim-pot to find the "good" value first..)
Alex Frias
I will try to figure out the circuit complete architecture to have a better vision of how it deals with the signal flow, but thanks for the tip anyway!
Maybe I will test to replace the LED's with Ge diodes...
As it doesn't implement SMD build it's great for modding this thing!
Alex Frias wrote:Maybe I will test to replace the LED's with Ge diodes...
I would first figure out the circuit. Sadly on the pictures some parts are hidden, but it appears to me, that the LED´s are configured like in a tube-screamer in the feedback-loop.
Has thanked: 218 times
Been thanked: 857 times
forget about this whole fuzz.
Where can I get those switches!?
andersom
my favorite amplifier: Valvepower 18 watt
Has thanked: 37 times
Been thanked: 7 times
Post by andersom »
About the switches closest to you would Germany..
http://uk-electronic.de/onlineshop/prod ... 8d6fa40d9a
€ 4,80
Hope thats what you are looking for
Alex Frias
Belcat may answer that!
AG, you're absolutely right!, the LED's are used in the feedback loop of the 741.
PmCimini
Has thanked: 23 times
Post by PmCimini »
andersom wrote:About the switches closest to you would Germany..
€ 4,80
Nope, those are 3P3Ts....
And btw quantos reais (how much is one of those pedals)??
Alex Frias
Basically R$ 120,00.
I'm finishing the circuit drawing. It's a very plain LED clipper on the feedback of an OpAmp, very basic. The input cap is 22nF and it uses a hi frequency rolloff cap after it of 1nF. Maybe I will try to make the input cap higher and put the rolloff cap out... and maybe a Ge diodes pair in antiparallel at the output of the OpAmp. I think it will make it soundo more like a fuzzy fuzz than like a "plain distortion" box.
Guilherme
Post by Guilherme »
At R$ 120 it may be cheaper than to import the switch and a hammond box...
Alex Frias
OK, but it's not at Hammond box level, it's very thin and a bit longer, but very usable anyway.
king_arthur
Post by king_arthur »
Hey, Alex! do we have do speak strictly english here?
i just got one of these fuzz, and i'm very happy with it.. but just like you, I would like it to clean up better. Did you mod yours successfully?
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
These are the switches
[url]http://uk-electronic.de/onlineshop/prod ... a40d9a[url]
Although the body is quite a bit smaller than the std blue 3PDT's the pin spacing is the same.
Ice-9
Post by Ice-9 »
Couldn't edit my last post so hopefully this link will work
king_arthur
I'm thinking of changing the caps. I think what gives the impression of "cleaning up nicely" is the brightness of the sound, given the right amount of gain so it doesn't clip too much. My question is: if i want the sound to be brighter, do I need an input cap higher or lower?
Alex, did you try to remove the output rollof cap? I might try that too.
atreidesheir
Has thanked: 441 times
Been thanked: 43 times
Post by atreidesheir »
I am pretty these are the same as Artec and Modtone pedals.
atreidesheir
I did a quick fix for friend at a gig on a modtone pedal; loose connection at the dc jack. It had the same Belcat pcb.
