Siegmund Microtube Double Drive gut shots
- bajaman
- Has thanked: 568 times
- Been thanked: 2014 times
Those tubes look like subminiature Russian tubes to me. Possibly 6N17B (6H17b) or 6N16B - they handle 200v easily and are similar two 12AX7 / ECC83.
They also have 8 leads just like the one in the pictures - they have 6.3v heaters though.
- culturejam
Static, can we get a shot or two of the power supply board? That would be interesting to see.
- bajaman
yep - most probably 6N17B
Urals shop in Siberia (on Ebay) has them at US$1.00 each or thereabouts.
staticinfinity wrote: in person they are pink/black/yellow. i'm gonna take a guess and say the pink ones are for brown since the cap is already brown. the resistor appears 4 places on the board. all the brown carbon comp resistors look like they came from the same manufacturer. The resistors under the 5 and 6th pots are yellow/violet/yellow. There is one with grey directly directly above the 3pdt (blue/grey/pink). There is one with orange in front of the third pot (orange/blue/orange) and one with red under the 47pf cap above the 3pdt (red/red/green).
If the stripe looks pink, it is actually violet, which makes them 700k resistors. This is a really odd value for this position and doesn't make much sense. Can you check them with a meter?
Honestly, I don't know if you can easily buy a 700k resistor, I can't find one at Mouser. Something weird is going on here.
Seeing as how the other tube had pretty low values for plate resistors, I am going to suggest you use a 6111. It has the lowest plate resistance of the 6111/6021/6112 types.
- bajaman
all the plate loads are 100k (for three tube sections) the other is a cathode follower to drive the tone stack. The 2k4 resistors are not plate loads, they are cathode resistors - also there is a 1k5 cathode resistor and of course another 100k for the cathode follower cathode resistor. Three dc supplies too - two ht supplies and a tube heater supply.
if pink=brown it's a 100k resistor. if pink=white it's a 900k. Do either of those values make more sense? If you look through all the resistors of that type, every color is there other than brown and white (including violet). The violet color on the other carbon resistors is not similar to the pink. What color would they use to indicate brown when the resistor is already brown? I'm not trying to be contrary, i honestly don't know.If the stripe looks pink, it is actually violet, which makes them 700k resistors.
http://www.friday.com/bbum/2008/12/15/c ... code-time/ I realize it relates to a lamp, but I also feel like i've heard of pink being sub'd for brown another time and it was when the color of the resistor would make brown hard to read. The pink is actually a flesh tone.staticinfinity wrote:if pink=brown it's a 100k resistor. if pink=white it's a 900k. Do either of those values make more sense? If you look through all the resistors of that type, every color is there other than brown and white (including violet). The violet color on the other carbon resistors is not similar to the pink. What color would they use to indicate brown when the resistor is already brown? I'm not trying to be contrary, i honestly don't know.If the stripe looks pink, it is actually violet, which makes them 700k resistors.
wow, you really know your stuff. Someone with you're level of expertize you could probably clone this thing.bajaman wrote:all the plate loads are 100k (for three tube sections) the other is a cathode follower to drive the tone stack. The 2k4 resistors are not plate loads, they are cathode resistors - also there is a 1k5 cathode resistor and of course another 100k for the cathode follower cathode resistor. Three dc supplies too - two ht supplies and a tube heater supply.
I still have the PS apart and i will do this later today, but it only open up enough to see part of it because of the wiring.culturejam wrote:Static, can we get a shot or two of the power supply board? That would be interesting to see.![]()
Aha, I had the tube backwards, makes much more sense.bajaman wrote:all the plate loads are 100k (for three tube sections) the other is a cathode follower to drive the tone stack. The 2k4 resistors are not plate loads, they are cathode resistors - also there is a 1k5 cathode resistor and of course another 100k for the cathode follower cathode resistor. Three dc supplies too - two ht supplies and a tube heater supply.
