Page 1 of 2
SoulSonic-Isolated A/B Splitter-Electronically Controlled
Posted: 31 Mar 2010, 06:03
by soulsonic
This is still a work in progress, but it's nearly done and it's verified on the breadboard. It's a simple A/B/Y splitter with a transformer-isolated output. What makes it different is that all the switching is done electronically. The A/B/Y selection is done with simple momentary footswitches that are controlling a flip-flop circuit. The flip-flop then controls a CD4053 to do the actual signal switching. It's all very 70's tech.
It also includes a switch to reverse the polarity of the isolated out - a very useful feature in some situations where you're mixing mismatched amps.
Here's what I have done so far:
- A-B_IsoSplitboard1.JPG (38.92 KiB) Viewed 4193 times
- A-B_IsoSplitboard2.JPG (39.43 KiB) Viewed 4193 times
You see, the pcb design I've done is 2-sided. It seems like it needs to be for it to be able to fit into this space without requiring a ton of jumpers. I was able to make this board with press n' peel, so you shouldn't consider it an impossible task to do yourself. The trick is to be sure it's well-aligned along two of the edges, and it should turn out fine. This layout is designed to fit into a 1590BB size box.
I'll upload the schematic and artwork after I get it boxed-up and have the final thing verified.
Re: SoulSonic-Isolated A/B Splitter-Electronically Controlled
Posted: 31 Mar 2010, 12:42
by RnFR
2 sides?
why didn't you just surface mount all the parts? despicable!
Posted: 31 Mar 2010, 22:08
by soulsonic
RnFR wrote:2 sides?
Well, I did use a bunch of surface mount resistors...
But I didn't want to mess with an SMD 4053 because I wanted it be in a socket because those sometimes die and need replaced.
Posted: 01 Apr 2010, 03:28
by coldcraft
wow, now this is cool!
Posted: 12 Apr 2010, 07:41
by ALDOUSCROSS
its not SHARING its SHOW OFFing
Posted: 12 Apr 2010, 19:38
by sinner
ALDOUSCROSS wrote:its not SHARING its SHOW OFFing
Oh, nice, Dick is back... Your real name is Dick, am I right... I remember your post from Earthquaker Devices Ghost Echo tread...
if i decide to buy this one would i share it wid you dogs.... nahhh!!! i rather not..... a deal should be set for that... ciao amigos.... i have a biglist of the pedals i already cloned and in lined for clonning hahahahaha wanna take a peek it?...... hahahahaha
Quick search true your post and I see NO sharing posts from your side, so please STFU and go back to your hole you troll
Posted: 13 Apr 2010, 02:40
by phibes
Never piss of a Pol!
Posted: 13 Apr 2010, 06:14
by sinner
You know me Timmy Doll
I'm just a shy guy with an lovely, silky smooth personality
Posted: 13 Apr 2010, 15:23
by phibes
Shy guy with a Viking beard!
Posted: 13 Apr 2010, 15:35
by sinner
phibes wrote:Shy guy with a Viking beard!
I've told you that's family thing, my grandfather had one, my mother to
, now it's my turn
Posted: 13 Apr 2010, 16:05
by 5thumbs
Nice looking work, Soulsonic. Inspiring to see someone pull off a DIY 2-sided layout, so now I'll have to try it. Thanks!
(Adding ALDOUSCROSS to foes list...wanker.)
Posted: 14 Apr 2010, 03:31
by soulsonic
Thanks guys. I will try to get this finished soon so I can have the circuit fully verified, and then I'll post it up. I'm definitely going to draw up a new layout for sharing, because this one doesn't center correctly in the box... I added something and forgot to shift the layout, so the LEDs are slightly off center. The new layout will not have the jacks on board, so you will have more freedom with how to mount it in the box. It was really hard to get the box drilled so that everything lines up right.
Posted: 14 Apr 2010, 04:10
by phibes
Looking forward to it!!
Posted: 23 Apr 2010, 00:53
by soulsonic
Finally got this thing working right today.
I finished last weekend, but something was wrong with it... would pop really bad when switching channels. Picked it back up today and found the problem - a small error in the circuit board layout. It was easily fixed and it works perfectly now.
Here's the guts:
I was careless with the spacing of the footswitches and now I can't fit a battery in there!
You'll probably notice things on the front panel are all off-center as well... this pcb layout is definitely off. I'm going to scrap it and draw a completely new one. Schematic is incoming... just have to get it drawn up.
Posted: 23 Apr 2010, 01:16
by KindaFuzzy
Cool foot switches.
Posted: 23 Apr 2010, 04:45
by phibes
Seriously sexy!
Posted: 23 Apr 2010, 10:42
by Silent Fly
Very nice soulsonic.
The footswitches look similar to these
these.
They look flushed to the surface... how are they compared the standard footswitches?
Posted: 23 Apr 2010, 14:01
by Grendahl
The closest approximation I could find on a similar "vandal resistant switch" was this.
http://www.bulgin.co.uk/Products/Switches/Domed.html Their MP0037/3 looks pretty decent.
There are a lot of them that are lighted too, but most of the lit top ones aren't domed enough to stomp on.
Also, most of the vandal resistant switches I have seen are only momentary, so you'd need to use relays with them.
Posted: 23 Apr 2010, 14:10
by DWBH
Cool!
I'm planning on doing the whole flipflop+mux AB box myself as well, but I was wondering: what are transformer isolated outputs, yadayadayada?
Posted: 22 Jun 2010, 06:57
by jmwreck
sinner wrote:ALDOUSCROSS wrote:its not SHARING its SHOW OFFing
everywhere this man goes, he ends up with a fight, (referring to aldouscross), he talks a lot of B*LLSH&T.
