Echolette E51 - heads
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
where can I buy recording heads for this tape echo?
thanks
Boris
thanks
Boris
- Dirk_Hendrik
Can't help ye buddy.
But you've just pinpointed, spot on, the reason I never do tape echo repairs.
- borislavgajic
- Opamp Operator
Dirk_Hendrik wrote:Can't help ye buddy.![]()
ooo man mister Dirk....if you (anf fiew others) can't help me ......than
but can someone explain how circuit for erasing works......there is oscilator and little trafo.....so it is multivibrator ecc82 creating sound that is inaudible....and that is how tape is erased?
http://www.schematicheaven.com/effects/ ... _ng-51.pdf
writing heads were replaced with some strange little ones...and I could not measure them with ohmmeter....I've opened one ,and it was isolated with little plastic part from input cable...
help please
I could find heads from some old magnetophons????....or modern tape recorders?
thanks
Boris
- analogguru
The erase oszillator normally runs on 100 kHz, so it is inaudible.
A part of this 100 kHz signal is also used to "bias" the tape (to reduce distortion).
