ampless ac15 2x10 impedance
- RnFR
i picked up an ac15 2x10 missing the amplifier, and now i want to make something of the blues loaded in this nice sounding little cab. anyone have any idea what the impedance rating would be for 2 of these 10" celestions blues?
the celestion site only has info for 12"ers. thanks!
- lolbou
AC15s are 15 ohms... Are these unwired so that you can't figure out if these were in series or parallel?
Two 8 ohms in series could make it then... In another thread here, someone told me that the DC resistance of the coil would be a little below the actual impedance : did you check it?
BTW I remember that the impedance of the GT-75 I had in my old Valvestate was stamped with ink on the speaker frame.
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- RnFR
they are wired in series. so 15 ohms? the amp i'm using is a bogen chb50, and it has adjustable taps for the output impedance. i believe one of which is set for a 16 ohm load. i'll give that a shot then.
thanks for the help, lolbou. i really need to study up on the whole subject of amplifier output sections. i still feel a bit vague im some areas.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 69 times
- Been thanked: 65 times
- Contact:
About everything Celestion, do not hesitate to ask them directly :
http://professional.celestion.com/guita ... /index.asp
I had some kind and helpful answers from Dr Decibel about those in my old Valvestate (Lolbou : it's a 8240, do we have the same amp ?).
- lolbou
What about finding an AC15 chassis and make yourself one? Would you like the sound of this amplifier for your own taste?RnFR wrote:now i want to make something of the blues loaded in this nice sounding little cab.
Nope, I had two 8080 mk1. I really liked these -easy maintenance/mods when needed- but sold them both for a Hot Rod. I do miss the overdrive channel sometimes though...JiM wrote:Lolbou : it's a 8240, do we have the same amp ?).
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Contact:
And i was proud of my stereo setup ...lolbou wrote:Nope, I had two 8080 mk1. I really liked these -easy maintenance/mods when needed- but sold them both for a Hot Rod. I do miss the overdrive channel sometimes though...JiM wrote:Lolbou : it's a 8240, do we have the same amp ?).
Just the overdrive channel is not very complex : http://www.drtube.com/schematics/marshall/pc0689.pdf
There's five opamps, but also a high-voltage 12AX7. You can do it without the need for the MS2015 switching opamp, which may be hard to find. You may try and replace the tube with JFETs à la Runoffgroove, and make it into a stompbox. I just don't know if a cathode follower transformed into a source follower still behaves the same (especially the grid-current thing).
Back on topic :
I seems that the speakers were series connected, at least in the '90s reissue : http://www.voxshowroom.com/uk/amp/ac15tbxrear.html
The various versions of AC15 amps all seem to have 8 Ohm and 16 Ohm taps on the OT. http://www.voxamps.com/support/circuits/
But i did not find precise info about a dual 10" blue version ...
Do you have pictures ? It might be a really rare and valuable item.
What happens if you measure the resistance over each speaker and multiply this value by 1.3?
- Aharon
WELL................if you have a meter measure the impedance.You don't have to multiply ,the reading will be more or less 7 Ohms for an 8 Ohm speaker and 15 for a 16 ....more or less.
Aharon
Aharon
