Terminal Strip / Terminal Lug Help
Ive been contemplating building the austin treble blaster thanks to RG keen. I am however very concerned with the amount of information available with this procedure. I am pretty noob, but wouldnt you run the risk of having components short out on each other when soldering to a terminal strip?
Ive been searching the web trying to find the answer to this question. Can anyone just point me in the right direction?
Thanks much!
Thanks much!
- Hides-His-Eyes
I still can't get over you americans and your "Soddering"
Not really....
check out rg keens austin treble blaster here http://www.geofex.com/Article_Folders/R ... er/drm.htm
it is a pedal built using one terminal strip with the components all over the place.
Wouldnt the leads from components short out if they're touching each other? Do I have to put this together so they are all spaced out so the leads dont touch any thing else?
- RnFR
oh god, not this again...Hides-His-Eyes wrote:I still can't get over you americans and your "Soddering"
i just saw about 50 youtube comments about this same thing. idiots arguing over this like it actually matters. youtube comments- it's like the land of the lost sometimes.
