Eagle library has disappeared.
- JOHNO
Any one seen it? This shit is doing my head in. Ive down loaded eagle for mac and started to lay down the shcemo for the buzzaround alike pnp version. So it was all going kinda well accept I couldnt seem to lay down only half an opamp, is this possible in eagle? Anyway I save the shit come back to do some more work on it and now when I hit the add tool the library window pops up but there are no parts listed just a blank window. WTF?
Johno
Johno
- Grendahl
I'd suspect that somehow the library you've been using is no longer selected for use. Set it up again by following the instructions here: museum/gaussmarkov.net/tools/software/e ... e-3-setup/JOHNO wrote:Any one seen it? This shit is doing my head in. Ive down loaded eagle for mac and started to lay down the shcemo for the buzzaround alike pnp version. So it was all going kinda well accept I couldnt seem to lay down only half an opamp, is this possible in eagle? Anyway I save the shit come back to do some more work on it and now when I hit the add tool the library window pops up but there are no parts listed just a blank window. WTF?
Johno
Resistance is futile...
( if < 1 ohm )
( if < 1 ohm )
- JOHNO
Thanks a million for that Grendahl. I downloaded the libraries from the sight also, so should be a lot easier to find the components im looking for. I,m going in to have a play and try to get this board done. Thanks again
Johno
Johno
- Grendahl
You can get DIY Layout Creator, which seems to be a popular favorite of folks on these forums, or you can select something else. I have a few links on my site that might prove interesting. http://www.grenfx.com/index.php/tools/JOHNO wrote:Now when select a component and click ok the stupid computer just sits there and looks at me. Fuck this eagle shit its goin in the trash
( if < 1 ohm )
( if < 1 ohm )
