Right angle pcb mount pots
squrl
Post by squrl »
does anyone have another source for these pots?
http://www.smallbearelec.com/Detail.bok?no=692
impossible to find them somewhere else and smallbear is out until july.
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
I asked the same question a couple of months ago.
There doesn't seem to be another source.. I think smallbear has them made to spec.
squrl
Post by squrl »
goddamn monopoly!
Grendahl
Been thanked: 7 times
Post by Grendahl »
http://www.banzaimusic.com/PC-Mount-Ver ... irection=1
http://uraltone.com/kauppa/index.php?ca ... 2i49ij27u2
Those were the first two links found when I googled "16mm right angle potentiometer". Hope it helps!
Resistance is futile...
( if < 1 ohm )
telecaster
Has thanked: 162 times
Been thanked: 12 times
Post by telecaster »
I got some from mouser a few weeks ago as Smallbear was out of stock for the ones I wanted. Steve gave me the part numbers. They were a little more expensive though.
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
squrl
Post by squrl »
can you post the part #? i've searched mouser a few times and couldn't find that type...
telecaster
Sorry , they appear to be out of stock as well. You might be better off to wait for Smallbear. I checked my order with Mouser and it was from March. I'll give you the part number though if that helps.
Mouser part# , 313-6100f-250.
Alpha part#, RV16A-42-15R1-A250k.
This is an example for a 250k audio pot. Just substitute the last numbers for the values you want.
I just checked again, 42 in the alpha part# is for long pin. 41 is for short pin that you are looking for. There are no short pin available at mouser.
Greg
Post by Greg »
"No Results Found For "313-6100f-250." "
