Cusack - Tap-A-Phase [gutshots]
- culturejam
The layout and look of it on the inside reminds me a lot of the Malekko Ekko 616.
- Jack Deville
I dunno.
Different component selection, power/signal tracking follows a different scheme, ground plane on one side instead of both, 3PDT switch employed instead of relay/controller scheme, even the silkscreen looks different. There's a few other big differences I can spot.
Maybe though...who knows.
Nice design and execution.
- culturejam
Hey, I've been totally wrong on a number of other occasions, so I don't see why this would be an exception.Jack Deville wrote:I dunno.
- Dirk_Hendrik
I second that.Jack Deville wrote: Nice design and execution.
(even while being in the Atmel and not Microchip PIC camp)
- quaternotetriplet
any one traced the relay switch that cusack uses?
- marshmellow
There ain't much to trace. The microcontroller is waiting all day long of his boring life until the guitar player stomps on the switch and then toggles the output that is connected to the relay. Probably via an additional switching transistor due to the current demand of the relay.
- quaternotetriplet
his claim it last longer than our good old friend 3pdt.. is that true?marshmellow wrote:There ain't much to trace. The microcontroller is waiting all day long of his boring life until the guitar player stomps on the switch and then toggles the output that is connected to the relay. Probably via an additional switching transistor due to the current demand of the relay.
- Jack Deville
I wouldn't dismiss the system so quickly. There is a bit more to this design than you will observe with the first glance.marshmellow wrote:There ain't much to trace. The microcontroller is waiting all day long of his boring life until the guitar player stomps on the switch and then toggles the output that is connected to the relay. Probably via an additional switching transistor due to the current demand of the relay.
I think the controller is doing a little more than relay management in this one too.
Certainly is. IIRC that relay is rated at 10^8 cycles, compare w/ the 3PDT switch which is rated at 2*10^4.quaternotetriplet wrote:his claim it last longer than our good old friend 3pdt.. is that true?
I've personally observed over 400,000 cycles of my relay system without fault/failure/performance loss. Can't say I've seen a 3PDT switch pull that kind of duty.
- marshmellow
Sure, it also serves the tap tempo/LFO duties. And I didn't mean to dismiss anything at all. As I already mentioned in the other recent Cusack thread, I really like his approach for the bypass, because I do it just the same way. The only thing I would have added, since already using the µC for the LFO, would be an envelope control mode.Jack Deville wrote:I wouldn't dismiss the system so quickly. There is a bit more to this design than you will observe with the first glance.
But still, I'm with Mr. Hendrik on the Atmels.
- Jack Deville
marshmellow wrote: But still, I'm with Mr. Hendrik on the Atmels.
- Dirk_Hendrik
Which is an entirely different task compared to a simple timer for the taptempo, bypass control or waveform generation (which are just way simpler and less complex when being done in software).marshmellow wrote: since already using the µC for the LFO, would be an envelope control mode.
To do envelope control one requires AD conversion. That's fairly easy for an average PIC or AVR but one can wonder if the usual 8-bitters in these controllers are fast enough to follow the signals envelope and convert that information to the control output (assumed PWM) accordingly.
yes they can. I've done it.Dirk_Hendrik wrote:one can wonder if the usual 8-bitters in these controllers are fast enough to follow the signals envelope and convert that information to the control output (assumed PWM) accordingly.
- jimbob_400
There more to the switching system.
If you hold down the switch you can turn the bypass LED on or off, at least on my screamer fuzz you can.
Also when the battery is going low the LED will start to flash and then after a while when you plug it in the LED will flash and the pedal will refuse to turn on until the battery is replaced. I think if you press the switch with a low battery the LED flashes and the pedal stays in bypass.
- Jack Deville
So it begins...
There's more too.
There's more too.
