Anyone have this one? http://www.guyatone.com/Wr2.php
It's soo good sounding to me, had an idea to build one, but no luck on schematic
that was a very good advice, thanks mandevastator wrote:Maybe Guyatone gives schematic, I think I read that somewhere (not sure).
You explain that you've a broken pedal and want fix it .
ebuprofen wrote:that was a very good advice, thanks mandevastator wrote:Maybe Guyatone gives schematic, I think I read that somewhere (not sure).
You explain that you've a broken pedal and want fix it .:D:D
so now, I have the schematic, but have trouble with the switching. Can anyone tell me what should I do, to replace the electronic switching, with TB? I a bit confused
Why bother? The pedal won't affect your tone when disengaged, and it will actually help by doing an impedance reduction for you!LooseCannon wrote:Thanks
Any idea about the switching?
because that's what he wants?mictester wrote:Why bother? The pedal won't affect your tone when disengaged, and it will actually help by doing an impedance reduction for you!LooseCannon wrote:Thanks
"True Bypass" is usually a waste of time.
I mean that you're going to remove Q2, but you'll still want that connection it makes between R26 and R6. I'm thinking you'll want to do the same thing to Q5.LooseCannon wrote:Thanks square wave!
I'm gonna breadboard it and see how it works.
What do you mean by short Q2?
