Hi there!
I'm looking for the correct connector in the Eagle's library. I want to mount this, I think that the pass between each pin is 0,25 cm (like the title of the item suggest) but I can't find anything like that in my libraries.
madbean wrote:Here's one with a 6-pin. See if it works for you.
_Molex.zip
I think this size it's ok. But it doesn't work well:
1) I can't wire the pin
2) overall, I can't separate each pin on the schematic, I can only move the entire piece
_Molex.zip
1) Wire to the little piece that juts out from the circle.
2) Fixed
_Molex.zip
2) Fixed
