Where to get (old) LM 741 and RCA 741?
Lonkero
my favorite amplifier: Tech 21 trademark 10
Post by Lonkero »
I live in Finland, where there are only a few store selling op-amps. I've been trying to find the LM741 and RCA metal can version (which is supposed to be quieter) but don't know which would be good place to buy them? In my country the few shops sell only new ua741 op-amps.
Even better would be if I could obtain some original 30+ year old 741 op-amps to my dod 250 project. Maybe somebody can help me?
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Lonkero wrote:I live in Finland, where there are only a few store selling op-amps. I've been trying to find the LM741 and RCA metal can version (which is supposed to be quieter) but don't know which would be good place to buy them? In my country the few shops sell only new ua741 op-amps.
Why? Do you like hiss?
The 741 was one of the noisiest op-amps ever made, and wasn't really designed for audio use. If you use an NE5534 instead, your pedal will sound exactly the same as an original one, but without the hiss.
The 741 doesn't have any mystical musical properties, and you'll just be wasting your money if you're suckered into buying "NOS" parts!
Lonkero
Post by Lonkero »
When it comes to some things, I have a purist in me :D
Noise ain't a problem cause I run NS-2 with all the dod pedals. Even the YJM 308 which has the KA4558 is supposed to be low-noise op-amp but it ain't. Hiss is as loud in it too.
I've learned that there all are the great new improvements which suppose to replace the olds, but if they're so great why are not everyone using the new stuff? Cause there are differences which some of us can hear
Enough offtopic, lets keep focusing on the parts obtaining!
uncleboko
Has thanked: 57 times
Been thanked: 38 times
Post by uncleboko »
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
DeanM
my favorite amplifier: Marshall VM 2466
Has thanked: 21 times
Been thanked: 5 times
Post by DeanM »
Well with the 741s in old DOD250's it wasnt the NOS chips that made the sound. it was just that they took advantage of the poor specs of the 741. 741's have a pretty bad slew rate and so were slow to react to higher frequencies and that led to a smoother top end than with other faster chips. so it worked well in that simple circuit.
I remember seeing RCA 741's online somewhere!! and it was within the last two weeks i saw em!! cant remember where the hell i saw em tho!! il try remember and if it comes back to me il let you know!
sadrew
Been thanked: 14 times
Post by sadrew »
ebay has plenty... do a search for LM741 TO-99
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
I´m sure that a NS-2 kills more tone than any old super-duper mojo IC can deliver...
JOHNO
Has thanked: 47 times
Been thanked: 53 times
Post by JOHNO »
Wiki says that RCA became defunct in 1986 when GE brought them out. I have about 50 used RCA CA741 opamps. These are from the late 60's or early 70's i'm not sure. Now if you check the RCA data sheet you will notice that it says on the first page that the CA741 is identical in specification to the LM741. If you would really like one of these opamps I'd be happy to satisfy your need for this "mojo chip" if that is what you want to call it, and send you one in the mail. But I've built 250's with these CA741 chip's, and your garden variety LM741 chips and the results are the same. But if you really want one pm me your address and I'll send you one.
Johno
Lonkero
Post by Lonkero »
JOHNO wrote: But if you really want one pm me your address and I'll send you one.
Johno
That would be great! PM Sent :P
marin
my favorite amplifier: Komet
Completed builds: meteor
orange squeezer
dod250
bassballs
FF
TS
Post by marin »
as Dean said, the 741 has limited bandwidth but wether that could be called smooth is another thing. having in mind that those and these adjectives are arbitrary i say that dod250 with 741 gets additional distortion to the notes after 12th fret E. it does sound bold and great. with 741 you have a thing not dissimilar to exciter. if not aural than certainly audible.
there is NO more hiss than with 4558 variety.
snmavronis
Completed builds: My DIY stompbox builds:
- Neo-Classic 741 Overdrive (gray spec 250 Overdrive clone)
- MXR Distortion+ (diy replica pcb replacement 1980 block logo)
- Neo-Classic 3080 Compressor (script spec Dyna Comp clone)
Post by snmavronis »
The closest I got ahold of to the RCA 741 IC chip is this:
JOHNO wrote:Wiki says that RCA became defunct in 1986 when GE brought them out. I have about 50 used RCA CA741 opamps. These are from the late 60's or early 70's i'm not sure. Now if you check the RCA data sheet you will notice that it says on the first page that the CA741 is identical in specification to the LM741.
Does this mean that my CA741 metal can is from the 19th week of 1979 according to the date code 919 at the bottom if I'm reading it correctly? The only reason I might use it is that it could be from the same period (1979-1980) that my DOD is based on.
You're right though it sounds no different when I compared this than the 84' Motorolla LM741CN dip version that I'm using anyway. I think the datasheet says the DIP version has a higher temperature range than the Metal Can version.
Guitar > Boss NS2 Noise Suppressor > NS2 Send > MXR Custom Comp > Neo-Classic 741 Overdrive > NS2 Return/Output > VHT Special 6 Ultra Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
leeknpotatosoup
Post by leeknpotatosoup »
At my university we have heaps of them just lying around everywhere haha
snmavronis
leeknpotatosoup wrote:At my university we have heaps of them just lying around everywhere haha
What does your university have an op amp graveyard? LOL.
I know using vintage parts doesn't really make anything sound better, but it adds a certain coolness factor to your clone especially if it is from the same time period as your subject is.
marin
orange squeezer
dod250
bassballs
FF
TS
Post by marin »
I'll PM you leeknpotatosoup. :cheers
leeknpotatosoup
snmavronis wrote: What does your university have an op amp graveyard? LOL.
Yeah we were using old parts to look at the noise in op-amps, turns out they're pretty noisy compared to the modern versions, but still not bad.
If anyones keen I could send some in an envelope for free.
