Switching effect on/off
gruforevs
my favorite amplifier: Fender Deluxe Reverb '65 reissue
Post by gruforevs »
This is a really n00by question but I still must ask it. What should be used for a switch to switch an effect on or off? SPST OR SPDT?
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
It depends how you want to switch and what exactly you want to switch.
Most effects use a 3PDT footswitch.
The extra set of contacts is used for the LED indicator.
You can get away with a 2PDT if you use a few extra components.. search "Millenium Bypass".
gruforevs
Post by gruforevs »
I just want my guitar signal to be affected when it's on and not be affected when it's off. I don't want/need an led or anything like that. In this case, which type of switch should I use?
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
DPDT.
blenk
Post by blenk »
Ok ive just got a DPDT footswicth, can someone help me with wiring it,
- - Effect input and effect output
- - jack in and jack out
- - Jumper theses too
is that right?
Do i not need a ground?
Hides-His-Eyes
That is a perfectly acceptable way. there is an alternative with a ground if you want it.
blenk
Post by blenk »
cool as long as i dont need the ground that should be fine thanks
