the schematic is correct BUT the PCB is wrong, HOWEVER the PCB works fine so no need to panic
The REALLY IMPORTANT thing to note, is that the 100 resistor and 220uf capacitor decouple the fuzz face transistors part of this circuit OR you will get enormous hiss from the circuit when running it from a 9v DC power supply without this power supply filtering.
The op amp does not need this filtering as it has it's own internal filtering
The PCB includes the power supply decoupling to include the op amp supply - no problem though, although it does not require the extra filtering.
Hope that makes sense to you all.
I can change the PCB tracks to match the schematic but it really does not make any difference to the circuit's operation - honestly!!!
