DOD - FX25 Envelope Filter  [schematic]
tubehead123
Post by tubehead123 »
Mbas974 wrote:Hi all, I'm very happy with my pedal I built some time ago, everything is working well.
One question related to this circuit but O.T.
Will it be possible tweak the circuit in order to not have the envelop ?
Let me explain... this pedal is extremely silent that only when I play sound come out... in other words it is a GREAT GATE pedal.
So I was wondering whether I can mod it to change it in a standard GATE without the envelop.
...hope it is clear.
it has low noise prolly due to two things - low gain to not make self-noise or increase any incoming noise and a filter to cut out any high frequency noise. also, the filter is at its lowest position with no input signal which is what you want for a noise gate. if you wanted to make it into more of a gate you would want the filter to be a lowpass (see my lowpass mod) and instead of using an envelope derived from the input signal level, use a square wave instead, e.g. as long as you have signal the filter is at max position.
HullorHell
Post by HullorHell »
Hi All,
I've just been given a DOD FX25 pedal from a friend who got in a pickle trying to fix a broken wire and ended up doing a really bad job of rewiring it. I don't understand wiring schematics so I wondered if anyone had any pictures of the guts of this that they could share so I could trace where each wire should be?
Gila_Crisis
Been thanked: 68 times
Post by Gila_Crisis »
I got again after ages a DOD FX25B, and I did few mods to it.
- C11 up to 22uF to have a better, not so quick decay.
- changed R5 from 20K to 10k, this solves the volume drop and gives the filter the bite many says is missing in the FX25B.
- BP/LP switch (with a volume trim on the LP side to have unity volume)
- since this filter is very similar to the Korg MS20 VCF, I added a switch to select betwenn the DOD envelope, or flipped it becames a fixed filter with the additional pot to set the cut frequency.
Ichabod_Crane
Has thanked: 25 times
Been thanked: 13 times
Post by Ichabod_Crane »
I built the circuit of the DOD FX25 on veroboard sometime ago, but I got a sort of huge boost of the bass just in the tail of the decay, making my amp vibrate! Then I completed the Snow White, veroboard. It's nice, but I guess the decay pot doesn't do anything. :hmmm:
Gila_Crisis
Ichabod_Crane wrote:I built the circuit of the DOD FX25 on veroboard sometime ago, but I got a sort of huge boost of the bass just in the tail of the decay, making my amp vibrate!
That's the magic of the FX25 :mrgreen: :mrgreen: :mrgreen:
