Dirk_Hendrik wrote:Other than that, what's the reason for the series-connection of those 1n and 10n caps?
Because buying large quantities of one size is cheaper, I guess...
Has anyone already made a layout?
OhDirk_Hendrik wrote:Thus the question remains, why is a gain control called "level"? (while the only reason it will suggest level is because that tonestage gives such an attenuation that with a make up gain of 2 it will still suggest being turned all the way down)
Correct about the component choices! I always choose to repeat the same few values throughout a circuit - when you're making a batch of them, it's a lot cheaper.roseblood11 wrote:Dirk_Hendrik wrote:Other than that, what's the reason for the series-connection of those 1n and 10n caps?
Why not? If you want to use 4n7 instead of two 10n in series, feel free. However, it's much cheaper to stock large numbers of a smaller range of components.Dirk_Hendrik wrote:....
but to publish a circuit as such...?
mictester wrote:Why not? If you want to use 4n7 instead of two 10n in series, feel free. However, it's much cheaper to stock large numbers of a smaller range of components.Dirk_Hendrik wrote:....
I don't stock (for example) 30k resistors, but have loads of 33k. I needed 30k for a potential divider (the other values worked out to more standard values) so I used 33k // 330k which worked fine, and didn't take up much more board space. I mostly just stock the E12 values.
By the way - try the "James" passive tone control. The values I gave were right for guitar (double the capacitors for bass). The range of control is remarkable (try simulating it), and you can get the "classic" scooped mids, extreme treble boost , woolly bassiness, and even a flat response. It's one of the best tone controls I've ever used, despite being lossy.
You're welcome, Ian. You might want to have the option to break a connection to the 10n in the input stage - you might also want to be able to change it. It looks mostly OK so far, and I'll keep checking it for you. Also - think about another board for the bypass indicator!irfrench wrote:Evening.
Ok so I took the dive into creating PCB layouts.This seemed complicated enough to start with!
I've attached the schematic, layout and pnp as .pdfs so they'll be to scale.
Mictester (or anyone!) - please take a look over this to make sure all appears correct.
As I say, it's my first layout so be gentle!
Please note the jumper in line with C15.
Also this is minus the bi-colour LED and Millenium Bypass.
THANKS FOR THE SCHEMATIC MICTESTER!
Ian.
mictester wrote:I decided to put an op-amp "wrapper" around the standard BMP clipper stages, and add my favourite tone control for real versatility. As drawn, it sounds really good, but has more top end than a normal BMP because there's no input loading effect. The capacitor in the feedback around the first op-amp stage could be increased in value (I have 47 nF there at the moment), to give a roll off similar to that which the original transistor input stage would cause, but other players like the brighter top end, so I've left the diagram as originally drawn (on a napkin, in a pub!)
This is a "halfway" design - I was going to add electronic switching, and some other modes of operation to the "full" version. You'll see that it can be switched to "Jumbo Tonebender" mode in this version.
In the next version, there will be "Stock Old", "Stock New", "Russian", "Creamy", "Jumbo", "Swollen" and may be other modes too. These will be selected by electronic switching. It also occurred to me that it might be worth allocating two sounds to two foot switches, so that it was easy to switch between a low gain "Russian" mode and a screaming "Creamy" mode.... The possibilities are endless, and I know I'm going to end up building loads of these with preset resistors inside and DIP switches to select sounds, and no external controls except the bypass footswitch!
Here's the circuit schematic as it stands today, and this is a really worthwhile version: Enjoy!
mictester wrote:I revisited this circuit over the last few days. It occurred to me that one of the biggest changes that you can make to the clippers in a Big Muff if to vary the collector resistors (try 4k7 or 5k6 all you "low gain" freaks and prepare to be pleasantly surprised!). I had a supply of 100k dual log pots (used in my mixers), and decided to try making the collector resistors for the clippers variable. My first attempt tried using a single pot (I'm cheap like that) but it wasn't terribly good. Going for the dual pot, wired as two variable resistors is amazing - it goes from less than the usual Big Muff tones right up to an uncontrollable screaming monster! It occurred to me to reduce the collector resistors in series with the pots - 6k8 was found to be a good minimum. The pots can be 47k (or 50k) or you can put 100k resistors across them if you find that the maximum gain is useless (I did).
It will be interesting to see how soon this pot configuration turns up in some Boutique version of the BMP!
